Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 11-24-2006, 05:41 AM
mac4lif mac4lif is offline
high RPM's, Trans wont shift out of 1st, help please
when Im driving my car, It's like the trans does not upshift, and the Rpm's are in the 4 and 5 at 40 to 60 mph, can someone help. thanks everyone.............................
Old 11-25-2006, 10:52 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: high RPM's, Trans wont shift out of 1st, help please
Welcome to AF.
It would be helpful to post the year of your Aurora and engine size. Also, mileage.
Timeslip 08/12/06
AF Community Guidelines
Old 01-04-2007, 12:54 AM
blong1385 blong1385 is offline
have you checked your trans fluid levels. very easy to test. easy to fix
Old 01-17-2007, 09:19 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
shift solenoids possibly
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 01-18-2007, 11:45 AM
baron1701 baron1701 is offline
An Egr Vavle Or Tps Sensor Can Cause This. The Pcm Will Not Shift Into O/d If These Are Out Of Sync. I Had This Problem When I Swapped Out My Tps Sensor With One That Was Bad.
Old 01-29-2007, 12:29 PM
elhombre elhombre is offline
I guess it stucks in the 2nd gear (failsafe mode), my Aurora has a similar problem. Are there any DTC set? The shift solenoids seems to be a good place to start. Unfortuantely, my car has a different problem.It probably has a PCM failura or other electrical error.
Baron: I didn't check the EGR and TPS sensors yet. Did your car shifted into 1-2-3rd gears and it missed only the 4th? Do you know a sure method to check the TPS and EGR sensors? I have a Tech1.
