Old 11-17-2006, 09:07 PM
MooseNelson's Avatar
MooseNelson MooseNelson is offline
Let's get at that oxygen sensor!
Hello troupe,
do I need to remove the fan to get at the sensor on this 1992 eagle summit 1.5?
from above or below and with a wrench?
-NOOB
http://www.georides.com
Sub Compacts, Electrics, Biodiesel, hydrogen
Old 11-17-2006, 11:08 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Let's get at that oxygen sensor!
I wouldn't take the fan shroud off. Hit the parts store and grab yourself an O2 sensor socket. Its a 7/8" socket with half of one side cut out for the wire.
Another thing I've done before, but its risky... is to cut the wires off and then use a regular socket. Problem is, if you can't get the old one out you can't drive it to the exhaust shop for help
Dragging people kicking and screaming into the enlightenment.
Old 11-17-2006, 11:56 PM
UncleBob UncleBob is offline
AF -Advisor
are the 4 bolts holding the fan on that hard to get too?
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 11-18-2006, 05:14 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
like curtis said, this is what you need.
Seatbelts Saved My Life
Old 12-03-2006, 11:23 AM
Reg Saretsky Reg Saretsky is offline
Send a message via AIM to Reg Saretsky
What is the best loosening compound
to use to get the sensors( there are two) off my Dad's 1993 ranger 4.3?
I swear the lil b......gers be welded on
Advise....
Cheers Reg
Old 12-03-2006, 12:32 PM
importloverh22 importloverh22 is offline
To get a stuck o2 sensor, try some wd-40 or some other lubricant on the threads. Also, run the car for a minute or two to get the exhaust warm, not HOT, but warm. That helped me get my o2 sensor off my 94 accord. Looks like it was the original one on there after 160k miles. Hope that helps.
1994 Honda Accord Coupe 160k miles
1985 Toyota MR2 138k miles
Cars just don't have character until they have over 100,000 miles.
