Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 11-17-2006, 06:32 PM
junkthatmoves junkthatmoves is offline
Question blinker problems
I have an 89' grand marquis. Im having problems with the turn signals. I have replaced all the taillight bulbs, flashers and there are no blown fuses and I still cant get the turn signals to work. The hazard lights work so Im pretty sure that there isn't a problem with the circuit so Im wondering if there is a hidden fuse link anywhere that might need replacing or if the whole signal switch on the steering column is bad. Before I have to chase wires I want to know what i can try before I start that process.
Old 11-18-2006, 10:01 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: blinker problems
Welcome to AF.
Your post has been moved from Car Buying Q & A to the proper forum, Mercury Grand Marquis. See link below.
http://www.automotiveforums.com/vbul...d.php?t=645039
Timeslip 08/12/06
AF Community Guidelines
Old 11-18-2006, 10:49 AM
Vanagon-tom Vanagon-tom is offline
Post Re: blinker problems
Did you fix the problem? I had the same problem on my car. It ended up being the 4 way hazard switch. Hold down the 4way hazard switch and see if the turn signals works. If you look on most wiring diagrams, the turn signals and the 4 way hazards tie together.
quote=junkthatmoves]I have an 89' grand marquis. Im having problems with the turn signals. I have replaced all the taillight bulbs, flashers and there are no blown fuses and I still cant get the turn signals to work. The hazard lights work so Im pretty sure that there isn't a problem with the circuit so Im wondering if there is a hidden fuse link anywhere that might need replacing or if the whole signal switch on the steering column is bad. Before I have to chase wires I want to know what i can try before I start that process.[/quote]
Old 11-19-2006, 04:47 AM
KimMG KimMG is offline
AF - Advisor
Make an enlarged copy of the wiring diagram, test each component in the circuit until you find the fault.
