LOW COOLANT n Leak
this is my 1st time in here, I have an 01 chevy Impala that im actually aboutto sell but just today it started leaking a tremendous amount of coolant i looked in and around radiator but saw no leaks, i looked under the car and seen that its leaking all under by the trans oil pan,can any one help im not very mechanic oriented
Re: LOW COOLANT n Leak
just found out the the leak is coming from the manifold gasket wich need to be replaced and the bypass house.
The intake manifold on the 3.8 is too thin in one area and will deteriate (possibly due to the dex cool) and begin to leak. Better auto parts stores sell an improved intake manifold that suposedly alleviates the problem. The 3.4 engine has a similar problem but is repaired with just a gasket although it is major PITA to replace.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
Yep, definate problem with these cars. YOu will want to replace all gaskets that come in contact with the dexcool or you will have problems. Mine leaked in the area of the exhaust too and ruined my CAT converter (not cheap)
PITA to replace. I have to now replace the intake manifold gasket a 2nd time. I love spending $1000 at a time....
![]() See :http://www.automotiveforums.com/vbul...d.php?t=649821: Last edited by luvmy02impala; 12-20-2006 at 09:40 AM. |
I had this problem and just needed a new radiator cap. Mine still seems to go through the coolant, but much slower than before. |
