DC Sports shifter done...
Got my short-shifter in today. What a pain. Why does it seem like every mod I do to my car requires me to remove my center console?! If I had a dollar for every time I took the center console out, I'd have another civic to work on!
Anyways, installed the shifter bushing too, but I'm still grinding, so it's probably my tranny fluid? The throw is really nice, super short, and the way the shifter is angled, I don't have to sit all crooked to reach the shifter... Wish I had some time to change my tranny fluid before heading to OR, but oh well... P.S. Question: My energy suspension urethane bushings came with 3 bushings. The funky-shaped one for the Torsion bar mounts, and then 2 spacer looking bushings... I only used the one for the Torsion bar, and I'm not sure what the other two are for... Anybody know? P E A C E
LOL! I had the same problem, I was like WTF are these donut looking things!? They go on the end of the stabalizer bar (where it attaches to the tranny). Its sort of hard to get at the bolt for it but you can and then just do your best to pull out the rubber bushing and putting the poly bushings in is easy since they are 2 pieces.
http://www.fourthgenhatch.com FOR SALE: Get this stuff out of my house! -Stock hood (red) $30 -Stock Rear Spoiler (red) $30 -Stock mirrors $30/both -Stock side front and rear side glass $30/piece |
Congrats on installing the short shifter, they kick ass. I think your grinding might be because of worn out sychro's, and tranny fluid can only temporarily fix the grinding.
10 PRINT "MARC-OS 0WNZ J00!!!" 20 GOTO 10 RUN 4/8/04 - My CRX is officially dead, RIP Lucy
does the dc sport shifter from a 5th gen civic fit on a 4th gen?
zc powered 89 CRX SI with some more stuff. |
I believe so. When I got the shifter in the mail the other day, the package said "88-95 civics"...
I have been trying to get him to start posting on AutomotiveForums, but he is a hardcore Honda-Acura.net guy.
AF Bay Area Crew ![]() 97 Toyota T100 xcab 3.4l v6 5spd 2wd |
I think the reason they shake is because of the ball on the shifter is smaller than the stock ball which is the pivoting point. I noticed if I tap my shifter a little it moves back and fourth with no real resistance, I never noticed that with the stock one. So I believe that is the reason. But nothing to worry about though.
the bushing are for the shifter & the stabalizer on the tranny side. use all the parts it came with & LUBE LUBE LUBE all the CLEAN bushing before install.
The bushings for the front are kind of a pain to get in. You are replacing the one piece stock bushing with the donut things. Lube a lot (use that white grease) and I was able to get at it pretty easy with two regular old wrenches..kinda a slow process, but I couldn't fit a socket up in there..as mentioned above, kinda a tight fit...but the bushings do help isolate vibrations and and stablize the whole assembly.
If you shifter is rattling, you might not have the bolt tight enough that bolts the shifter to the linkage..too tight and you can't shift, but it is a locknut so it is "adjustable" ..did your shifter come with new o-rings and stuff for all that at the bottom of the shifter? I bought a B&M short shifter...I loved the parts it came with to replace the old stuff (u pop the old sleeve out of the bottom of your stock shifter and replace all the o-rings and re-use it), however, I do NOT like the shifter itself...it needs to be angled back in the hole thru the floor..it is a straight shifter and I have to reach way up to grab the thing
-Shawn '91 Civic DX sedan DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
