Old 11-07-2006, 04:22 PM
mrmartin23's Avatar
mrmartin23 mrmartin23 is offline
DTC code problem
Greetings.
I own a 1996 Pontiac Firebird Formula-1. I am failing emmissions due to a DTC P1661 code. I looked up the code and see that it is a Mil low error but cannot find a fix for it. Is it just a burnt out bulb for the check engine display or something else? Help would be most appriciated.
Old 11-07-2006, 09:29 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: DTC code problem
I think that means your check engine light bulb is burnt out. Its a brand-specific code that doesn't always show up in the standard OBD2 list.
Dragging people kicking and screaming into the enlightenment.
Old 11-07-2006, 09:34 PM
mrmartin23's Avatar
Thank you very much. Now how in the world does that stop the emmission test? OK off to the parts store to get a bulb. Are they hard to get to or can I access it from under the dash?
Old 11-07-2006, 09:36 PM
curtis73's Avatar
During the emissions test they have to verify that the light is functioning. If its not functioning you can't pass.
