Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 11-06-2006, 01:15 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
passlock I new ignition lock relearn
if you replace the ign lock in a 98 that has passlock I(no resistor in key) then do you have to relean the security system ?
can yo do it yourself or can only a dealer do it ??
thanks
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 11-06-2006, 01:26 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: passlock I new ignition lock relearn
In a '98 what model? If it has Passlock you can try taking ignition to on for at least 10 minutes and off for 30 minutes. You may have to repeat. The theft deterrent module or BCM module should learn the new coding of the ign. lock cylinder. Good luck.
Timeslip 08/12/06
AF Community Guidelines
Old 11-06-2006, 01:34 PM
hi there it is an achieva
we tried all this, once the security light finally was blinking after i had disconnected the battery and the BCM and cleaned all contacts, so i let it sit with the key on til it stopped blinking and was solid and the it was fine for about two weeks, now its doing it all over again but worse than ever, will not stay running for nothing and all the guages and lights are fluttering and innacurate and all over the place worse than ever too, even the blue headlight indicator lamp in the IPC continously blinks all the time when its running/driving
i tried everything, to no avail, or for not very long anyways
the new ign lock didnt help one bit at all, even though the dealer said it was bad
so i pulled the IPC again and am having it sent in for a rebuild or replacement
any thoughts here ?
thanks!
Old 11-07-2006, 08:46 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Well from what I understand the security light willl flash 5 times, then it should go out, not stay on.
Need to do the relearn again till the security light goes out with the key in the "ON" position. just my
1999 Grand Am SS 3.4 OHV
Old 11-07-2006, 09:00 AM
BNaylor's Avatar
I believe he has other issues JC but since we have the make and model established I moved this thread to Olds Achieva. Also, he has a thread on the IPC and Southern Electronics, a company that repairs IPCs.
Timeslip 08/12/06
Old 11-07-2006, 02:04 PM
I see !
