Go Back   Automotive Forums Car Chat > Buick > Century
Old 11-06-2006, 01:30 AM
djirene4206 djirene4206 is offline
Alternator?
When driving with headlights on (1996 Century Special 3.1L) at certain speeds the lights will continuously flicker (headlights, dash lights, etc.) If I speed up past the certain speed - like 50mph, it stops. If I hold the speed, it keeps flickering. Could this be a rectifier (diodes) or Voltage Regulator in my alternator/generator going bad? My system voltage measures 14.5 volts after start and battery holds charge. I know alts cut on to regulate voltage more at certain RPM's, It is a 105 amp alt, and does seem to make a squealing noise when engine is at idle. I have been through every wire in the car - there are no shorts unless they are in side the transaxle housing.
Old 11-06-2006, 09:16 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Alternator?
How many miles are on your Century and that alternator. Sounds like you found your problem to me.
Timeslip 08/12/06
AF Community Guidelines
Old 11-06-2006, 12:14 PM
Re: Alternator?
130k
Old 11-06-2006, 12:56 PM
BNaylor's Avatar
Re: Alternator?
Go for the alternator. Probably not just a bad internal voltage regulator but bearings and stator/rotor. Good luck.
Timeslip 08/12/06
Old 11-06-2006, 03:08 PM
ricebike ricebike is offline
Re: Alternator?
how's the condition of the belt? maybe it's stretched/worn to the point that it's not being properly "tensioned"
having 14.5v seems to be working ok, but you can always goto an autozone or advance auto parts for an on-vehicle diagnosis of the alternator/battery/starter test for free right in the parking lot!!!
Old 11-07-2006, 04:28 PM
musclecarfan6's Avatar
musclecarfan6 musclecarfan6 is offline
Re: Alternator?
Same thing happened to my dad's Dodge. The lights would flicker and act really wierd. Turned out the alternator wasn't putting out enough amps. Changed it and it was fine.
95 Plymouth Neon 2Door 2.0L SOHC
89 Buick Century Custom 3.3L
____________________________
What to see pics of my cars. Go
to www.cardomain.com and look
for musclecarfan6. Rate or leave
comments if you want.
Old 11-12-2006, 04:53 PM
Re: Alternator?
First off, thanks for responding to my problem, guys. The belt is new, and I just replaced the tensioner a month ago. (it was in terrible shape - my buddy that owned the car before me treated it like s__t! Now that its in better hands, I am doing everything I can to transform it into a better car. I have the working repairs down (hopefully) to the alternator and the transaxle. The bearings in the alt. do seem to make a racket at idle speed. I am installing an ammeter soon since all I have is an 'idiot light'; hopefully I will know before my car stops on the street. I have decided to replace the alt. with a higher amp 140A version - hopefully I can buy it soon - will keep you updated as to whether or not it fixes the problem. Thanks again for the suggestions!
