Old 11-05-2006, 10:12 AM
Nutsforcars's Avatar
Nutsforcars Nutsforcars is offline
How to best paint window trim on clear plastic?
Hello all,
I ran into a problem, I don't seem to be able to solve. I am building a Tamiya Mercedes SLK. The windshield needs to painted on the inside and outside. The areas to be painted are slightly "shaded" in the clear plastic.
First, I tried to paint with a brush but I was not satisfied with the results.
My second try was to mask and spray. Masking with masking tape did not work as I cannot see the shaded areas through the tape in order to get a good border. It worked a little better, when I used BMF for masking. I should mention, that I dipped the windshield in "Future" to be able to repair any mishaps. After masking, I sprayed a coat of Future on the windshield to seal the masking, then Tamiya X18 (semi-gloss black). After removing the tape, it did not look satisfactory. The lines are not as crisp as I had hoped and are not exactly where they should be. Also, the future leaked through and created a hazy area between the trim and the clear windshield.
To make a long story short: How do you paint these window trims on the clear pieces?
Thanks
Jens
Old 11-05-2006, 10:34 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: How to best paint window trim on clear plastic?
Use a small permanent ink pen and draw the border lines (four sides, except for the corners), using a french curve. Then, fill the rest of the area with a larger pen of the same brand. If the type of black matches, you can use paint, instead.
If you don't like a french curve not conforming to the window, find identical curves and transfer them to a sheet of plastic, cut them out and use them as guides.
Hiroaki Fukuda
Old 11-05-2006, 11:21 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
I do it the same way as Hiroaki, using a permanent marker. But I usually freehand it. It does require multiple layers to build up to a thick black hue.
-Mike
Old 11-05-2006, 12:14 PM
tigeraid's Avatar
tigeraid tigeraid is offline
Authorized Vendor
I use a sharpie for the small stuff as well... but if it's a 1-piece window glass, I mask it all off using either body tape (the green stuff autobody guys use) or Tamiya's own tape, and then use a very sharp #11 to lightly cut out the outline of the trim. Tamiya usually includes masks already in the kit for this very purpose, as well.
Old 11-05-2006, 01:31 PM
bhop73's Avatar
bhop73 bhop73 is offline
Mask and airbrush for me.
http://www.italianhorses.net/Tutoria...asks/masks.htm
http://www.bhop73.com/
Old 11-05-2006, 01:51 PM
Thank you for your responses. It seems there is no magic available. I will try the masking and spraying using the technique in bhop's link. I will also try the marker technique and see what works best for me.
Cheers
Jens
Old 11-05-2006, 01:57 PM
Jay! Jay! is offline
Horizontally Opposed
Alex Kustov's handy tutorial on the subject:
Hierarchy of Subaru:
(Click to see mine!)
Old 11-05-2006, 04:33 PM
Lownslow's Avatar
Lownslow Lownslow is offline
black sharpie then use tamiya flat black with a paintbrush
Old 11-06-2006, 08:56 AM
KTem's Avatar
KTem KTem is offline
Doesn't the new SLR kit come with window masks?
Old 11-06-2006, 11:50 AM
tpliquid tpliquid is offline
Send a message via AIM to tpliquid
this whole time i been masking up and wasting time.. I will try this marker technique now
friends let friends drive benzes
Old 11-06-2006, 01:23 PM
924_CarreraGTS's Avatar
924_CarreraGTS 924_CarreraGTS is offline
He said Mercedes SLK, which is significantly different from the SLR. It is also a lower-quality Tamiya kit.
