Old 09-11-2002, 09:30 AM
greykey greykey is offline
Angry 93 Escort won't start
This morning went to start the Escort. Just a solinoid click, no turn over. Battery checks out just fine at 12.7 V. Cleaned the battery terminals. No change.
Any ideas?
Thanks.
Old 09-11-2002, 03:36 PM
Heep's Avatar
Heep Heep is offline
Send a message via AIM to Heep Send a message via MSN to Heep
Most likely the starter. I had the same thing happen to me, sometimes it would just click (just once when I first turn the key), then other times it would crank very slowly. Since you know the battery is good, try starting from a boost...if the car starts, then you know it's the starter...it's gone bad and now needs more power than just the battery can supply in order to crank the engine.
Don't be too worried, the starter isn't all that expensive, and it's fairly easy to change yourself, just 3 bolts and 2 wires.
________________________________________
Mark Brown
1991 Volkswagen Jetta (1.8L I4/5-speed/FWD)
Old 09-16-2002, 07:03 PM
Thanks for your reply. Turned out that the battery didn't have enough amps to turn the car over. I jumped it, took it to a shop and got a new battery.
Thanks again,
greykey
2003 ZX2 won't start uspres2020 Escort 14 01-31-2010 12:01 AM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
'97 Escort-won't start-not battery-won't turn over HelpSingleFemale Escort 3 12-02-2005 04:58 PM
92 Escort won't start but will push start robyn144 Escort 4 07-21-2004 08:19 AM
Escort won't start jon mcar Escort 5 08-08-2003 11:03 AM
