Old 10-31-2006, 04:19 PM
jerry_rickard jerry_rickard is offline
Please help w/ location of solenoids!
My 99 gtp just threw a code 1811 and from the research on this site I think it's the pcs solenoid. I heard the tcc solenoid is right by it in the valve body.? Does anyone please have diagrams or any helpful info on how to get to these? I work at a pretty big tire shop, would it require special tools? If someone has skimatics or diagram i'll be very thankful.
Old 10-31-2006, 05:45 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Please help w/ location of solenoids!
The important part is getting the transmission side cover assembly off which is a job all by itself. Once off you will see the complete valve body assembly. The TCC-PWM and PCS solenoids are located on the left hand side. The TCC-PWM is right below the PCS solenoid. If you plan on doing it DIY then good luck because you will need it.
For general GM FWD procedure:
Side Cover Removal:
Disconnect the battery ground (negative) cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Starting and Charging.
Remove the throttle body air inlet duct. Refer to Air Cleaner Intake Duct Replacement in Powertrain Management.
Install the engine support fixture. Refer to Engine Support Fixture.
Remove the engine mount strut. Refer to Engine Mount Strut Replacement in Engine.
Raise and support the vehicle. Refer to Vehicle Lifting.
Remove the left front wheel. Refer to Tire and Wheel Removal and Installation in Steering and Suspension.
Remove the left engine splash shield. Refer to Splash Shield Replacement - Engine in Body and Frame.
Remove the stabilizer shaft links from the lower control arms. Refer to Stabilizer Shaft Link Replacement in Steering and Suspension.
Remove the left tie rod end from the steering knuckle. Refer to Steering Knuckle Replacement in Steering and Suspension.
Remove the wheel speed sensor harness connector. Refer Wheel Speed Sensor Jumper Harness Replacement (Front) in Brakes and Traction Control.
Remove the left lower ball joint from the left steering knuckle. Refer to Steering Knuckle Replacement in Steering and Suspension.
Disconnect the left drive axle from the transaxle. Refer to Wheel Drive Shafts Replacement (Left) or Wheel Drive Shafts Replacement (Right).
Secure the drive axle to the steering knuckle/strut. Caution: Failure to disconnect the intermediate shaft from the rack and pinion stub shaft can result in damage to the steering gear and/or damage to the intermediate shaft. This damage may cause loss of steering control which could result in personal injury.
Remove the pinch bolt at the intermediate steering shaft. Refer to intermediate Steering Shaft Replacement in Steering and Suspension.
Remove the intermediate shaft from the steering gear. Refer to Intermediate Steering Shaft Replacement in Steering and Suspension.
Disconnect the three-way catalytic converter pipe to the right (rear) exhaust manifold. Refer to Catalytic Converter Replacement in Powertrain Management.
Support the right side of the frame with jackstands.
Support the left side of the frame with jackstands.
Remove the transaxle mount bracket. Refer to Automatic Transmission Mount Bracket Replacement.
Remove the transaxle mount. Refer to Automatic Transmission Mount Replacement.
Loosen the engine mount lower nuts. Refer to Engine Mount Replacement (Front) and Engine Mount Replacement (Rear) in Engine.
Loosen the right side frame to body bolts. Refer to Frame Repair in Frame and Underbody.
Remove the left side frame to body bolts. Refer to Frame Repair in Frame and Underbody.
Adjust the jackstand to the lower left side of the frame.
Position the drain pan under the transaxle.
Remove the wiring harness connector.
Remove the case side cover bolts (56-58).
Timeslip 08/12/06
AF Community Guidelines
Old 10-31-2006, 09:20 PM
troy1 troy1 is offline
AF -Advisor
special tools = engine hanger and 6hrs R&R
Old 10-31-2006, 09:41 PM
BNaylor's Avatar
4T65E Solenoid Location:
Timeslip 08/12/06
Old 11-01-2006, 06:23 PM
you guys are awesome, thanks for all the help. i think i might be over stepping my boundaries. i guess i'll hand it over to aamco. thank you so much for the time and effort. if anyone in atlanta needs wheels or tires come see me. 770-631-1444 Jerry Rickard
Old 11-02-2006, 06:27 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Sorry Jerry, I had to edit out your company name. Considered unauthorized advertising on this forum.
