Old 10-31-2006, 07:56 AM
theblurr87 theblurr87 is offline
Send a message via AIM to theblurr87
battery dead, couple questions
So the battery finally died at 107k miles, I'll itemize.
Car was dead so I jumped it, and drove it to work fine, except for an annoying whine coming from the instrument panel (vac leak? alternator?). Tried to start the car up again when i got to work and it wouldn't, car was the same as before i jumped it.
1. Going to replace the battery first (i think it's still original ) Any recommendations/advice?
2. The cable for the neg. battery term is really corroded, what should i use to clean it?
3. Should I just get an alternator while I'm at it, in case that's where the whine in coming from? The whine is quiet at idle and increases with increasing throttle. I used to think it was my head unit, since when i turned the head unit off, the whine went away, but now it's there reguardless.
Thanks for any and all advice!
'99 SE (l36) 125k mi.
FWI | ZZP HVTB St. 1 | WP UD Pulley | 3" DP/HF Cat/U-bend Del.
Old 10-31-2006, 08:36 AM
rubberman rubberman is offline
Re: battery dead, couple questions
in my GP and my Montana the AC Delco battery cables fell off. corroded that bad and after reading some i found that AC Delco are prone to that. Then went to sears and bought a diehard. That whining could be the power steering pump or your tranny. just buy a battery and then go from there. Clean the cables with Coke or a wire brush.
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
Old 10-31-2006, 11:08 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Whats up Dude? Haven't seen you around for a while. I guess it is that time of year again with the cold weather setting in. I agree the battery sounds like a good starting point to me. Good luck.
Timeslip 08/12/06
AF Community Guidelines
Old 10-31-2006, 03:52 PM
jbizel's Avatar
jbizel jbizel is offline
I heard that using a toothbrush and baking soda is a good way to clean the corroded areas. then if you put vaseline on it then it will prevent corroding.
Old 11-01-2006, 09:35 AM
Thanks guys, it was just the battery. Everything is fine now and the whine is gone ::shrugs:: I have a nice pic i'll post a link to of the corrosion on this terminal. Thing wouldn't budge! just a good reminder to all to make this this doesnt happen to them
Yea haven't posted on here in a while, I usually go to clubgp, there's a lot of good info there but when i want to get good advice on maintenance or quality issues i come here lol
Old 11-01-2006, 10:26 AM
as i said on both of the AC Delcos batteries i had, the metal terminal basically fell off the plastic housing of the battery
