Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-30-2006, 11:34 AM
Erixon Erixon is offline
Problem with petrol tank level indicator
Hello, I have a problem with my Venture 97'. The petrol level indicator almost always indicate a full tank . But in my gas tank is just 15-20 liter or for sample 30 liter. Sometimes when I starting my engines indicator show as much is. Please help my with this problem, because i have several days ago stall out in midle of stret. Thank you in advance
Old 10-31-2006, 08:21 AM
fanta2 fanta2 is offline
GM Fan, but waning a bit.
Re: Problem with petrol tank level indicator
I have a 99 Venture with the same problem. The fuel sending unit is part of the fuel pump assembly on mine, so we're just tracking our gas used/mileage using the trip odometer until we need a new fuel pump. The new fuel pump assembly costs US $350, PLUS labor!
Old 10-31-2006, 11:17 AM
534BC 534BC is offline
http://www.automotiveforums.com/vbul...ght=fuel+guage
This thread helped me diagnose mine, it was the sender in the tank. The metal wiper arms on the float arm were just plain worn out.
Old 01-08-2007, 11:10 PM
townsaver townsaver is offline
Send a message via Yahoo to townsaver
My wife's 02 Venture just got out of the shop last friday for the same thing.
Too bad I wasnt able to convince her to just track her mileage since her last fill up. Half the cars ive ever owned aint had a working gas gauge..
But she is a nazi about running down to the very last drops of vapor in her tank, every time.
*sigh*
Old 06-26-2007, 03:27 PM
jwalker1970's Avatar
jwalker1970 jwalker1970 is offline
Inexpensive fix to fixing Venture/ Silhouette/ Montana fuel tank senders:
(I've done it at least 5 times, has worked every time!)
#1. Remove fuel pump assy
#2. Remove fuel guage & float assy from pump. Note, the float just unsnaps.
#3. clip the 2 lead wires (so they can be re-soldered back in place)
#4. Decide what type of sender you have:
A: Black in color
B: White in color
(this is the only two sender styles i've seen in the ones I've replaced. --the two colors Do Not interchange)
#5. Take a drive to the salvage yard. (I recommend asking for the guy who warehouses the parts, not the counter guy.)
#6. Ask him to match up the sender (not the whole pump assembly.--many, many different GM pump assemblies use the same senders. If you're lucky, they will sell you just the sender.)
#7. VERY IMPORTANT: Make sure the sender has "curls" on the slide end of the contact points. They should look like the letter "J" at the end, not just straight. Your worn out sender has ones that are straight (because the curl portion has worn out)
#8. snap the replacement sensor back into your fuel pump assy, solder & heat shrink the wires.
#9. replace the original float on the sensor.
#10. test outside the vehicle to make sure sensor is working properly
#11. re-install pump
NOTE: the sensor is not available by itself from GM. (or aftermarket that I've found). If you find a used sensor, or a complete pump with the same sensor you probably will spend $75.00 or less. This is much better than about $300 for a new fuel pump assy.
Good Luck.
Old 06-26-2007, 08:59 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Please check dates before posting. If you have new info, please start a new thread. Thank you.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
