Old 10-30-2006, 11:21 AM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
rpo codes
where is the rpo code list on a 89 irock
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 10-30-2006, 12:34 PM
poormillionaire2 poormillionaire2 is offline
Re: rpo codes
Check driver's side door or glove box.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 10-30-2006, 06:20 PM
Nate355RS's Avatar
Nate355RS Nate355RS is offline
Re: rpo codes
It's either there or in the lock box in the back.
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
Old 10-30-2006, 07:53 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: rpo codes
if its a thirdgen its on a sticker on the door of the locking compartment in the rear left. Could be under the armrest if its not there. I think some years had them there but maybe not
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 10-31-2006, 09:24 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: rpo codes
lock box, or center console
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 10-31-2006, 10:51 AM
Re: rpo codes
cool cant get the hach open right now tho no key and no batt
Old 11-01-2006, 09:38 AM
1986Z28's Avatar
Has a Camaro
Re: rpo codes
that sucks, got a brick?
Old 11-01-2006, 11:25 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: rpo codes
jason, the rpo sheet should be on the underside of the center console lid or on the drivers side door. if you want them decoded, put um up here and ill do it for ya or you can use the decoder on thirdgen.org or camarosource.ca
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
