Old 10-25-2006, 05:54 PM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
fuel pressure
i have a chance to trade that bronco in my sig for a 1993 chevy pickup with a 5.7L V8 TBI the truck has been totaled but the engine is good....if i did this i would want to put this engine into my 84 camaro fuel injection and all...my question is this ..............
how much fuel pressure does the TBI need? so i can know what pump i need to put in it
thanks alot
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 10-25-2006, 06:10 PM
twistedtech twistedtech is offline
Re: fuel pressure
TBI=13lbs
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 10-25-2006, 06:28 PM
Re: fuel pressure
13? i was discussing this with my dad yesterday and i was thinking that tbi was a relatively low pressure FI like about 15 or so.
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 10-25-2006, 11:08 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: fuel pressure
it is also ALOT of work to put a 350 in a 2.8 car. I would trade and sell the truck for parts or thw whole motor.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 10-26-2006, 09:03 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: fuel pressure
Yeah that's closer, 18-20psi depending on application demands.
Old 10-26-2006, 09:17 AM
Blue Bowtie's Avatar
Registered Offender
Re: fuel pressure
From what I've seen, the TBI220 on a 350 usually requires 11-13 PSIG. The same TBI on a 454 requires 17-19 PSIG.
Old 10-26-2006, 12:02 PM
Nate355RS's Avatar
Nate355RS Nate355RS is offline
Re: fuel pressure
Don't put a stock replacement pump back into your camaro. You should get at least a TPI fuel pump and probably something that flows a little bit better like a Walbo 255. Fuel pressure on the 305 and 350 are the same, but the injector sizes are different. What kind of power your making and injectors your using will determine what fuel pressure you will need. If you have the 350's stock sized injectors and stock motor you'll only need about 10-13 psi.
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
