Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 08-28-2001, 04:50 PM
urasula urasula is offline
engine misfire
hey all,
what happens when the engine misfires, and how do u know when the engine is misfiring?
Old 08-29-2001, 07:34 AM
G20-KIWI G20-KIWI is offline
It'll run like a pig, foul plugs, stall, piss you off then maybe get worse.
Check your plugs, leads, dizzy cap, coil, if its a p10 then it could be
the AAC valve, EGR valve, Throttle position sensor or maybe the
Mass air sensor ground as many people have said. If you read the
maintenance threads you'll probably find heaps of info.
-=G20-KIWI=-
Old 08-29-2001, 11:26 PM
P10DET's Avatar
P10DET P10DET is offline
Re: engine misfire
Originally posted by urasula
hey all,
Basically, it's an extreme incomplete burn of the mixture in the cylinder.
A misfire occures when fuel delivery is so bad or incorrect that the spark plug cannot burn the mixture completely. It also occurs (probably more commonly) when the electrical system is unable to fire the spark plug with enough power to burn the mixture completely. Or some combination of the above.
Sometimes you will experience a low rpm misfire. Sometimes it's high rpm. Sometimes in the middle (though less common), or sometimes all throughout the rev range.
It manifests itself as a "stumble" usually. Sometimes you can get through it by either applying light throttle or sometimes full throttle.
It's impossible to cover all types of misfire and what can be done about it, if anything.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
'99 Yukon misfires and won't start ZippyCT Yukon 10 05-29-2009 09:46 PM
02 Dakota Multiple/ Random Misfire, Cylinders 2,4,5,6 osuyaqui Dakota 3 04-09-2009 09:49 AM
Did engine swap now get PO455 code, engine misfire and smell mac4jr Elantra | Avante 0 02-03-2005 08:37 AM
Engine Misfire sc_customs C/K 1 11-24-2003 05:35 PM
engine misfire Skeme1 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 12-07-2002 07:35 AM
