Old 09-08-2002, 07:25 AM
shawoo2 shawoo2 is offline
Question Why am I burning Oil?
Okay, im sure the answer to this question can be a million different things but im gettn pissed here. I change my oil every 2000 miles, never see any oil drips on the driveway or anywhere. I usually burn like half a quart every time its time for me to change the oil.
Anything I should check/change when i change the oil next?
Old 09-08-2002, 11:50 AM
Rice_destroyer Rice_destroyer is offline
check your compression. if you're burning oil it's most likely your rings are getting fried and you're leaking in small amounts of oil into the combustion camber.
94 SI, B18B1, port n polished head, SRP 9.2 slugs, Eagle Rods, Total Seal rings, ARP bolts, Nuformz blockguard, MSD ignition, apexi V-AFC(hack), PYR chip(8500 redline), 450cc injectors, bbk f/p, custom T3 kit w/MP equal length manifold, huge intercooler, restrictive 2 1/2' exhaust
next mod: Hondata+GM MAP
Old 09-08-2002, 11:52 AM
MOG_22 MOG_22 is offline
Could be because it's leaking into the cylinders and getting burned up when you drive. This is what I would think is happening since you're not leaking oil on the ground when parked.
Old 09-08-2002, 07:07 PM
She only has 52K....still possible for the rings to go bad with such low miles?
Old 09-08-2002, 07:12 PM
YellowMaranello's Avatar
YellowMaranello YellowMaranello is offline
Send a message via AIM to YellowMaranello
Did you buy it used?
Old 09-08-2002, 07:13 PM
Yea, but the previous owner (1st and only owner of it b4 me) took crazy good care of this car. Had all papers for oil changes etc. Some older guy.
Old 09-08-2002, 11:22 PM
j.fuggi's Avatar
j.fuggi j.fuggi is offline
yea think thats bad, yesterday, around 2000 miles after my last change, the oil level didn't read on my dipstick. i made an emergency purchase of 2qts and filled my poor thirsty baby up. it sucks bad because i dunno why either. why would rings fry? i'm at 92k miles (damn last year at this time it was 79k)
» Supercharged 2006 Honda Civic Si Coupe
» Info | Teaser Video | Dyno Video | Dyno Graph
Old 09-09-2002, 03:19 AM
Do a compression test!! that way you'll know if your rings are bad. after that, do a leak down test to find out where the oil is going.
Old 09-09-2002, 11:56 AM
to do a compression test i need to take it to a shop or something right?
Old 09-09-2002, 09:26 PM
no, you need a compression tester. let me explain what it looks like. it's a gauge with a little hose that connects where your spark plugs are at(you have to take out the plugs first). i don't have a pix so hopefully that helps. it doesn't cost much either and would be a good investment if you plan on doing other things to your car. oh yeah, and if you do buy one and do the test yourself, remember to take out the ecu fuse before you do the test.
Old 09-10-2002, 03:56 AM
excivic excivic is offline
just to add my two sense, when ur drivin check to see if ur blowin blueish color smoke out the exhaust then youll definetly know ur burnin oil:smoka:
Old 09-10-2002, 09:40 AM
j.fuggi's Avatar
what if there's none? and oil level still decreases?-
Old 09-11-2002, 12:02 AM
b16a3sol b16a3sol is offline
compression and leak down tests are your best bet for finding the source of your lost oil. other than that you can look at your whole engine from the outside to make sure you are not leaking anywhere. check around the oil filter or anywhere else around the back of the the block. if it leaks out there, it will most likey burn off before it hits the ground, especialy at as slow of a rate as you are losing it.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 09-16-2002, 03:01 PM
yea i agree wit b16asol check around the whole engine for traces of oil cuz thats the only thing else i can think of check around where the head and block meet up also. If its not blowin smoke out the back then it shouldnt be burning its prolly jus leakin.good luck i wish i had more info to tell u.peace :bandit:
when the green light pops, the bullshit stops. =)
Old 09-16-2002, 03:09 PM
u prolly already did this but check ur oil pan nut to see if the seal is bad on it or if the nut itself isnt tight.peace :smoker2:
Burning oil at idle bhw33191 Caprice 20 09-13-2009 01:43 PM
smoking from the oil filler cap, dipstick and exhaust jimgbgt MGB 2 07-24-2009 04:26 AM
Why do LS1's burn oil? 2000LS1Z28 Camaro Discussions 43 05-28-2006 09:50 PM
burning oil, which oil is best? street hawk Intrigue 7 05-04-2006 02:32 PM
Burning oil after switching to synthetic oil RedRacerCivic '88 - '91 Civic | CRX | Wagon | Shuttlee 7 01-20-2003 07:50 PM
