Old 10-21-2006, 12:46 PM
badlude badlude is offline
Checking Honda ECU's
Does anybody know of a good place that checks out ecu's or rebuild's them? I have a 91 CRX hf.
Old 10-21-2006, 01:07 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Checking Honda ECU's
What's the problem? Usually if an ECU goes bad, you just get a used one.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 10-21-2006, 01:17 PM
I have no spark. No code light comes on at all, & the check engine light don't come on when the key is turned on. I have checked switch, fuses, igniter, main relay & some wiring. Any idea?
Old 10-21-2006, 02:34 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
If no light is flashing at all on your ECU, including the initial start up flash check for power coming to the ECU. If all seems ok, pick up another ECU (PM8 i believe) used from a scrap yard and try it out.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 10-21-2006, 10:12 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Pin B1 is the +12v power supply to the ecu from the battery. If memory serves correct, it should be a wht/grn wire.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 10-21-2006, 11:44 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
get a new one if the start up light (one flash) doesn't come on.
-tony-
2000 honda s2000
Old 10-22-2006, 12:57 AM
bambam89lx's Avatar
AF - Advisor
Only if he's not getting power to the ecu. A blown alternator fuse or a loose fat white wire on the alternator could cause this as well.
Old 10-22-2006, 01:12 AM
ah more wisdom, thanks
-tony-
2000 honda s2000
Old 10-22-2006, 11:09 AM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
you guys should soon put Jordan on payroll
Old 10-22-2006, 02:02 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
haha... just a thought.. check your hazard fuse on the strut tower in the main fuse box
it's the 10 amp one, I believe.. (blue?) anyone, it's like practically the only ATX fuse in the box... and it's all alone.. by the way, you can replace your stock ECU with almost anything that has EFI on it.
PM6 is the Si ECU For the CRX, not sure if it's the same for the Civic Hatch Si and Wagon, tho I would imagine it is, since they all had the same engine in them.
GL and happy driving.
Old 10-22-2006, 03:39 PM
bambam89lx's Avatar
AF - Advisor
hahaha....that's fuckin quotable. Thx for the love.
Old 10-22-2006, 03:45 PM
i couldn't afford jordan, i'm in the military, we broke.
-tony-
2000 honda s2000
Old 10-24-2006, 08:27 PM
Hey thanks people! After buying a Honda service manuel off ebay, I FINALLY got it going. It told me to check 4 wires coming out of the ECU for voltage & if it was more than 1 volt each, then the problem was between wires from ECU to thermostat housing. Guess what, those wires are grounded, or (supposed to be) to the housing. The housing wasn't getting grounded good to the block because of corrosion. You can use your Haynes manuels for door mats! Thanks again
Old 10-24-2006, 10:56 PM
^Honda FSM FTW
