Old 09-08-2002, 12:52 AM
BullShifter's Avatar
Short Ram Intake & Header
One thing to keep in mind when installing a header w/ short ram intake set-up. The factory manifold has a heat shield which plays a big role. When removing the heatshield & manifold you install a header thinking your gonna get a few ponies instead you get nothin cause the air flow into the intake is extremely hot. Engine like cool air. One thing you could do to prevent extreme heat w/ a header is to install header wrap, yeah its not the prettiest looking thing. $300 is a lot of money for nothing. Honda OEM exhaust manifold actually flow pretty good for stock compared to other makes. Cold-air or Ram-air is best way to go but then you run the risk of sucking up some water & that usually is not a good thing.:bandit:
Old 09-08-2002, 05:11 PM
mudbuddha mudbuddha is offline
Thumbs up
Good advise! I wrapped my header w/exhaust wrap and seems to get back some low end torque- highly recommended and looks racy too! Planning to wrap up my intake next.
1991 DX HB Hybrid
1990 JDM ZC DOHC 1.6L w/ SI tranny
I/H/E all custom by shop or by myself
A/C removed, San P/S
Lightened and Balanced Flywheel(10lbs), Centerforce Clutch, Chipped PG7 ECU, Ported throttle body and portmatch runners, Auto Meter water temp, A/F guages, Matrix Tach, Type R shif knob and custom short shifter
Custom 92-98 BC kit, Fender Flares for 18s' ALT rims on Sumho Supra 225/45/18
Custom 2001 M3 Grill insert and side mirrors. My favorite(my own creations): Custom LEDs Tail Lights and Custom Bluish, Silverish, Metallic Still Water paint.
Aiwa head unit and Kenwood amp w/matching Aiwa speakers and custom door mounted tweeter...
Future Mods: Zex or NOs 65 shots dry and possibly a Supercharging system as well as a Ram Air system of my own design. By then, a full rebuilt from block to Head w/ all the goodies
cold air intake or short ram intake for '94 4.6 liter tbird 3GRacing Thunderbird 2 01-22-2007 01:01 PM
Whats the difference between a cold air intake and a short ram intake? FenixDown Integra 29 04-10-2005 09:11 AM
short ram intake vs cold air intake? tipota Engineering/ Technical 7 04-02-2005 02:59 PM
short ram intake or just plain intake benfiquista21 '94 - '01 1 02-04-2005 11:30 PM
whats the different between cold air intake and short ram intake? corolla99 Engineering/ Technical 3 06-15-2004 08:49 PM
