Go Back   Automotive Forums Car Chat > Buick > Regal
Old 10-20-2006, 02:41 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
99 regal gs supercharged help
i got a 99 regal gs supercharged. a couple times today when i turned or even driving straight my steering was really hard like my power steering pump was low or something. my power steering was fine and sounded good. do you guys think its my belt slipping everyonce in a while cause im pretty sure they need replaced they squeel alot as of late
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 10-20-2006, 04:11 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 99 regal gs supercharged help
How many miles are on your GS? Also, do you have that variable ratio power steering option? Belt is always a good starting point. Can't beat a GoodYear Gatorback serpentine or supercharger poly v-belt. Also, make sure the belt tensioner is working properly. Located below the power steering pump.
Timeslip 08/12/06
AF Community Guidelines
Old 10-20-2006, 05:43 PM
it has about 65,000 miles on it. i dont know about the power steering option ill have to check it out. the tensioner on the power steering side seems real nice its actually the other tensioner for the supercharger belt im worried about replacing it moves alot when the car is running
