Old 09-07-2002, 10:31 AM
454Casull 454Casull is offline
Can coolant/oil channels be machined into a block or must they be cast along with it?
TIA
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 09-07-2002, 09:31 PM
AquaDave AquaDave is offline
Oil and colant channels are already drilled in the block. I'm guessing you want to modify them. you can drill them out bigger it's a task. most will drill out the oil ports then tap and insert orfices at the main and cam to assure all the bearings get even oil. if you have looked at a damaged engine you'll see that the main farthest away from the pump is the first to go. unless you are going for all out you don't need to fool with any of it.
Old 09-07-2002, 09:44 PM
Oh, so the channels aren't present in the block after the casting?
Old 09-08-2002, 08:37 AM
SaabJohan SaabJohan is offline
Thats right!
Old 09-08-2002, 10:40 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
depends on the block.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 09-09-2002, 02:38 PM
YellowMaranello's Avatar
YellowMaranello YellowMaranello is offline
Send a message via AIM to YellowMaranello
If they drill them into some blocks, shouldnt they be able to drill them into any block? unless.... oh. Blocks made of different materials... heh, nevermind.
Old 09-09-2002, 03:02 PM
Off the top of my head, I can't come up with a block material into which one couldn't drill oil passages.
When I said "depends on the block," I was referring to the fact that not all oil passages are machined. In some engines, there are cast-in oil passages in the block.
Old 09-10-2002, 07:06 AM
Great, thanks for all the info!
Old 10-02-2002, 01:46 PM
TheMan5952 TheMan5952 is offline
Volvo Guy
Send a message via AIM to TheMan5952
you can drill the blocks. Look at a LS/Vtec setup on a honda. Before the Vtec head can be put the block has to be drilled for a main oil line.
-Joe- '02 Volvo S60 T5
Sold!1993 volvo 850
Intake, Exhaust, Springs, Shock, I.C.E.
Cylinder 4 missfire along with burnt oil smoke Tal92on Engine, Transmission and Drivetrain 6 01-05-2009 07:38 PM
Should oil pump be replaced along with oil pan? Wheel7 Crown Victoria 3 08-23-2007 04:57 PM
