Old 09-06-2002, 11:20 PM
civ69's Avatar
civ69 civ69 is offline
Send a message via AIM to civ69
check engine light
Well I just installed a dc sports 4-2-1 header on my 92 civic, and after I drive for awhile the check engine light comes on. Everything was fine before I put the header on. I noticed that dc relocates the o2 sensor down by the collector, and have seen other posts about the extension cable causing too much resistance? anyway I reset the ecu by disconnecting the neg batt. cable, but light still comes on. Any ideas ..
Old 09-07-2002, 04:28 AM
ShStar333 ShStar333 is offline
Talking
HEY, I HAD THE SAME THING HAPPENED TO ME. HAD A 92 CIVIC EX AND EVERYTHING WAS FINE UNTIL I INSTALLED THE DC 4-2-1 ONE PIECE HEADER AND THE ENGINE LIGHT WENT ON. CHECK THE ECU CODE AND IT GAVE ME A CODE 43. I THOUGHT SOMETHING WAS WRONG WITH THE FUEL SUPPLY CIRCUIT BUT NOTHING. THE PROBLEM WAS THE OXYGEN SENSOR. CHANGED THAT AND RESET THE ECU, NOW EVERYTHING IS FINE.
Old 09-08-2002, 02:39 PM
civ69's Avatar
You know an easy way to check the ecu code, without taking it to a shop. The 92's dont have the led like on the older 4th gen civ's.
Old 09-08-2002, 09:05 PM
b16a3sol b16a3sol is offline
trip the wire that is down by the floormat on the passenger side. that is done by shorting it out with a paperclip or screwdriver. the check engine light will flash telling you the code. get a book that tells you what the codes mean and how to solve the problem.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 09-09-2002, 08:59 PM
civ69's Avatar
That wont fuck the ecu up will it??
Old 09-09-2002, 11:30 PM
thats what the wire was put there to do. buy a book.
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
