Old 09-06-2002, 07:45 PM
Heep's Avatar
Heep Heep is offline
Send a message via AIM to Heep Send a message via MSN to Heep
Have you ever used scroll lock?
Well?
I haven't, nor have I ever been able to figure out how it works, or if it even does work...
________________________________________
Mark Brown
1991 Volkswagen Jetta (1.8L I4/5-speed/FWD)
Old 09-06-2002, 07:54 PM
Damien's Avatar
Damien Damien is offline
Send a message via AIM to Damien Send a message via MSN to Damien
I know computers pretty well and I don't have a clue on what it does!
Old 09-06-2002, 07:55 PM
replicant_008's Avatar
replicant_008 replicant_008 is offline
If you are using Excel you can view cells around the whole spreadsheet without leaving the cell that you are currently 'active' on. This is useful, for instance, if you are writing a spreadsheet with lots of columns and rows and you are tracing the precedent cells in a large formulae.
I have some modelling in an Excel spreadsheet with 4 'if' statements nested within the same formula (it works out bonuses and long service loadings) and it's useful to verify the independent variables that influence the result without moving from the cell with the formula...
Old 09-06-2002, 08:04 PM
YellowMaranello's Avatar
YellowMaranello YellowMaranello is offline
Send a message via AIM to YellowMaranello
And now I know what it does, thanks to another excellent post from replicant.
Old 09-06-2002, 08:14 PM
Damien's Avatar
I don't have or never used Excel. Can it do anything on a regular computer?
Old 09-06-2002, 08:17 PM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
Nope me still confused
Old 09-06-2002, 08:24 PM
Damien's Avatar
It's a guess, but Taz, I think it just always allows you to use the arrow keys to move the bars to see the screen. I haven't found much more use yet of it on regular computers though.
Remember, it's just a guess. It does add color to your keyboard when it's lit!
Old 09-06-2002, 08:33 PM
I don't have any other use for it other than in Excel and Access using tables or arrays.
As for explaining the Excel thing. If you use the arrow key to move around in Excel, the cell that is active ie the one you can edit moves in the direction you are hitting the arrow key. So if hit the arrow key to the right you will eventually move from a1 to b1 to c1 and so on.
Now sometimes you have a formula that has lots of references to other cells. Now you may find you have an error or want to check the formula. You go to the cell (let say a1) which allows you to see the formula in the formula bar at the top of the screen. You can then see all of the cells that you have referenced in the formula (let's say AZ1 and B129).
Then if you press scroll lock, you can use the arrow key to move around the spreadsheet as you did before so you can look and see if AZ1 and B129 are the correct cells to use in your formula. However, the active cell doesn't move this time - it still stays as a1 and it means you continue to look at formula (to see your cell references) and you can edit the formula by hitting the F2 key without having to go all the way back to highlight cell a1.
Old 09-06-2002, 08:34 PM
Ssom's Avatar
Ssom Ssom is offline
Send a message via ICQ to Ssom Send a message via AIM to Ssom
*Presses scroll lock* Ooooooooooohhhhhh preeeeettyyyyyy
Replicant- If only I had known when I had to do my probability assignment
Old 09-06-2002, 08:41 PM
tazdev's Avatar
I'm still here
Ahhhh now I understand
Old 09-06-2002, 08:45 PM
Excel...
You find out these things when you write spreadsheet models for a living. Incidentally, I think I'm now into my 16th year using Excel - I started on a Mac Plus with version 1.0A.
Oh and try learning about the subtotal command sometime it will save you heaps of time.
Old 09-06-2002, 08:47 PM
primera man's Avatar
"P-Man"
I feel so much better now from reading all this....i to had no idea what it was for......
View All My Models Here.
Old 09-06-2002, 10:49 PM
Gonthrax's Avatar
Gonthrax Gonthrax is offline
Skyline Guy
Send a message via AIM to Gonthrax
When did you come to the circle Replicant? Do you know any of the other Kiwi AFers?
I'm just wondering 'cause you seem to be awash with usefull info, I hop into one thread and your giving out drink recipies, hop into another and you know what Scroll Lock is for
Sense I wasn't posting much when you joined and I didn't get the chance to, Welcome to AF
Member of AF's Slide Squad (Member #04)
Originally posted by taranaki
Postcounts - Phoey....it's not how often you speak,it's whether you actually say anything that matters.
Neishlin Motors
Soon to be my best friend
Old 09-07-2002, 02:50 PM
shadowboy's Avatar
shadowboy shadowboy is offline
Send a message via ICQ to shadowboy Send a message via AIM to shadowboy
the scroll lock pretty much is obsolete. it exists for legacy purposes.
on old IBM PC/XT keyboards they didnt have the cursor/movement keys in the middle (the number keypad had to do this)
the scroll lock locked it with the scroll functions, and num lock superceded it by locking in numbers.
try turning off your num lock and see what happens when you press '2'
Shawn
1979 Porsche 924S
1987 Honda CRX HF -- Project Chassis
1989 Acura Integra LS -- Project Parts Donor
Old 09-07-2002, 02:59 PM
tazdev's Avatar
I'm still here
the opposite of what happens when you press 8
Have you ever used a Ladder Caty Ladder Rack? laddercaty Automotive News Desk 0 11-10-2009 11:42 AM
Have you ever been pulled over? deftonez24 COMPLETELY off-topic 41 04-16-2005 10:11 AM
do you or have you ever gotten a P1870 code? Macgyver007 Blazer 9 12-18-2004 09:48 AM
Have you ever woken up and have no idea where you are? Rich COMPLETELY off-topic 24 12-07-2001 04:01 PM
