Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 10-15-2006, 09:01 PM
BostonKev BostonKev is offline
P0443
Hi All, I got this code and I would appreciate it if someone can tell me where is best to look. Thank you
P0443 - Evaporative Emission Control System Purge Control Valve Circuit
Old 10-16-2006, 09:45 PM
16th hippy 16th hippy is offline
Re: P0443
sounds like the purge valve is not working. or short in wires. might be able to help with a location if you tell me the year of car.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 10-17-2006, 08:58 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: P0443
your profile shows your car is a 01 impala. The purge control valve/solenoid is located in the following locations:
3.8 vin-K= just in front of upper plenum, slightly toward passenger side
3.4 vin-E= just behind throttle body on drivers side of upper plenum
check the wiring for loose/dirty/corroded connections and hard plastic vacuum lines for cracks/burnt areas/obvious problems before replacing the valve itself.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-17-2006, 09:21 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: P0443
I agree it sounds like a flaky purge solenoid.
The DTC is a Cannister Purge Solenoid Circuit Fault, meaning electrical related. The P0443 DTC sets because the output driver has failed the electrical integrity check. The output state is invalid. Always a good idea to troubleshoot the problem first before replacing parts.
I believe the poster has a SII 3800.
Purge Solenoid Location SII 3800
Timeslip 08/12/06
AF Community Guidelines
Old 10-17-2006, 08:21 PM
Re: P0443
It's the 3.8 and I'll try changing it. Thank you
