Old 09-06-2002, 12:29 PM
shads305 shads305 is offline
Lightbulb I have a question about the Mach 460 sterio and its settings
Ok I have a 99 mustang gt and it has that great mach 460 sterio. I listen to mostly hip hop and rap music. .And I want to know what the best settings for Bass, Trebbel, fade, balance, and what a goof volume is. Like if all the things where set in the middle From there what are the best settings to get the most clear sound and good bass and bump from the sterio and also play it at a good volume so that it bumps and I can feel some of the bass. Right now my setting are: fade is 2 clicks back from the senter. Balance is in the center. Trebbil is 3 clicks up from center and Base is 2 clicks up from the center. I usualy listen to it at valume range from 1 click below center or right at center. SO what is the best setting for good clear bass and bump with all around sound.
Please give me good info and details about it ok thanks guys...
Also what is the compresion thing on the cd player used for does that make it sound better for good bass and bumpness and clearity stuff.
Please give me examples aabout the audio settings and what not in full detail please. I do not want to buy or add anything to the sterio so remeber its stock and its the good mach 460 sterio.
thanks
Old 09-07-2002, 09:51 AM
94svt5.0's Avatar
94svt5.0 94svt5.0 is offline
I set my fade with one click favoring the back, balance in the middle, treble 2 clicks from the end, and bass set at the edge of the first "s" in "bass". It thumps good enough, since I listen mostly to classic rock.
Not sure about the compression setting. I would recomend hooking up an aftermarket cd player. They sound a lot clearer, but the wireing harness is abit on the expensive side.
More photos and Info/website!
1994 Cobra
-off road h-pipe
-superchips power chips
-mac cold air induction
-BBK aluminum underdrive pullies
-pro-m 75mm bullet MAF
-18" konig wheels with nitto 555 zr tires
-Ford Racing 65mm throttlebody
-Ford Racing king cobra clutch
-Ford Racing 3:73 Gears
-Ford Racing Aluminum driveshaft
-Bullit suspension/ springs,shocks,struts
-Aubrun HD limited slip Diff.
2002 subaru Impreza RS
- stock
1989 Toyota pickup 4x4
-K&N
Old 09-08-2002, 03:07 PM
cool.. keep posting stuff please thanks guys.
Old 09-24-2002, 10:25 AM
please keep posting and respond to my question thanks
I have questions about the test pipe. mattg3000 3000GT/Stealth 4 03-23-2010 10:55 PM
Question about the electric car and its engine. brentyoung Engineering/ Technical 4 05-10-2007 07:15 PM
questions about the 2.5rs speaker set up nfg7787 Impreza/9-2x/Outback Sport 1 09-15-2004 04:45 PM
can the Mach 460 sound system in the mustang GT play MP3's shads305 Mustang Talk 2 09-24-2002 10:24 AM
can the Mach 460 sound system in the mustang GT play MP3's shads305 Mustang Talk 0 09-10-2002 10:58 AM
