Old 03-22-2010, 01:30 AM
mattg3000 mattg3000 is offline
I have questions about the test pipe.
How hard is it to install it?
What do you need to install it?
Old 03-22-2010, 09:37 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: I have questions about the test pipe.
If were talking about with flanges, easy, just some bolts. No flanges then you're going to be cutting and welding.
Old 03-23-2010, 03:58 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
It may not be easy at all if the bolts are rust welded.
Old 03-23-2010, 06:04 PM
Polygon's Avatar
The Red Baron
Damn! Good point. I should know better. After all I had to cut about ten different bolts and a set of control arm off recently.
Old 03-23-2010, 10:55 PM
AutostradaVR4 AutostradaVR4 is offline
says he's in el paso, so hopefully you'll be able to break the bolts loose. WD40/PB Blaster is your friend!
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
