| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Stupid but fun idea
If you replace the rear shocks in a front-wheel-drive car with solid bars of metal, would the high roll resistance in the rear and lack of roll resistance in the front make for a very loose car that's fun to drift?
(Loose = tending to oversteer)
Re: Stupid but fun idea
This is why drift cars run very stiff rear springs and stout rear sway bars, and soft springs and usually no sway bar on the front. As for how much fun it would be... thats for the driver to decide.
it lost the idea of fun when you talked about drifting a fwd car.
Seatbelts Saved My Life
Kinda my thoughts also, ebrake drifting is not drifting.
Really? So all those corners I went around in several of my FWD cars with the rear end hanging out was just in my imgination? No suspension in the back of any FWD car would make it VERY tail happy at even low speeds, it wouldn't be hard to throw it at a corner and have the tail end let go and start swinging around. Its still controlable, just not in the same way it is in a RWD car.
A solid suspension is incredibly unpredictable and very skittish. In a nice smooth transitioning turn they are fine, but the slightest seam, pebble, or change in the road will instantly send it over the traction limits and you'll be backwards almost instantaneously.
The suspension can be stiff to maximize weight transfer properties, but the stiffer the valving in the shocks (infinite in your case) will make control more of an issue. Compliance and ability to absorb imperfections in the road are what make predictability. A good example is in NASCAR. How many times have you ever seen a Nextel Cup car get the tail loose and then be able to bring it back? Almost never. Once those stiffly sprung rears get loose, they're staying loose.
Dragging people kicking and screaming into the enlightenment. |
Instead of the horrible screeching of dragging locked tires, there was just a thunderous rumble mixed with a scratchy type sound. Just don't get too crazy or you might lose the sheet and start "wearing your tires unevenly". _____________________________________ Empty (as in abandoned, and un-surveillanced) parking lots are one of our great national resources. |
People like you make the rest of the forum look bad.
One other idea that came to mind was using 4x100 trailer wheels and tires on all four corners. They're a lot cheaper than new tires for my stock rims, and I'd be able to slide all four with a lot less financial guilt, but I'd worry that they'd fold in and damage my car, and I'd also wonder whether they'd fit over my wussy little stock brakes. Going tubeless might be a very bad idea.
get some old steel wheels and take the tires off...
makes some nice sparks. if you have a welder, weld "Skis" into the middle of the rim, and you can have a lot of fun. i saw that on a destruction derby type show once... redneck-drifting or something. best part is that if you weld skis on, you can just change them if they wear down and not have to buy new wheels all the time. |
Damn, I shouldn't have thrown out the rim I replaced when a drug dealer ran me off the road into a curb.
I don't know as much as these guys but I wouldn't have a solid suspension at all. I still want to see someone do it, curious.
![]() 1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD |
