Old 10-10-2006, 08:09 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
Question traction control off or is it ????
every thing worked fine befor
and now when the trac control is off it still works. i dont get it
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 10-11-2006, 06:03 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: traction control off or is it ????
Is the ABS light on also? If so, you couild have a bad wheel speed sensor (part of the hub bearing) or a bad/broken wire to one of them. If the ABS light isn't on, did you accidentally hit the trac-off button on the DIC? If you recently had heavy rain, it could also be water intrusion into the bearing, which may clear itself up.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-11-2006, 10:06 AM
no abs light but we did have a light rain
Old 10-11-2006, 10:16 AM
BNaylor's Avatar
BNaylor BNaylor is offline
What exactly is your complaint? Are you implying that the traction control system is still working when it is turned off or is it not working at all when you press the TC button?
Timeslip 08/12/06
AF Community Guidelines
Old 10-13-2006, 06:07 PM
with the trac off light on it still acts the same as it dose with the trac on
Old 10-14-2006, 05:32 AM
BNaylor's Avatar
What are the driving conditions? Is this under normal driving conditions or getting it on, burnouts, etc.? I recall the traction control system may still kick in under certain driving conditions even with traction control manually turned off. For example people that drag race their GPs have to remove the ABS fuse to totally inhibit TC. But that is not practical for every day driving and it will disable the A/C.
Timeslip 08/12/06
Old 10-14-2006, 05:56 AM
yeah just beatin on it
Old 10-14-2006, 06:13 AM
BNaylor's Avatar
Yeah, I figured that was the case. You'll have to live with it unless you can figure out away to modify the traction control system. I get the same problem. So do others. We've discussed the issue in the past if you check the old threads.
Timeslip 08/12/06
Old 10-14-2006, 03:32 PM
ok thank you
