Old 10-05-2006, 03:52 PM
TewSmooth18 TewSmooth18 is offline
Send a message via AIM to TewSmooth18 Send a message via MSN to TewSmooth18
97 Cavalier 2.2 - Rough Idle
I need some help. I have a 97 Cavalier 2.2L. My car started smelling like gas inside so I took it into the shop and they replaced the Injector O-Rings and 1 of the Injectors that was bad. The gas smell went away but after all of that then the car started to idle badly when at a stop or the car is in park and shakes. When I take off sometimes it is like it wants to stall out and die but it doesnt. The car has died twice but hasent died in quit some time now. I have replaced the plugs, plug wires, 1 injector (mechanic said the rest was fine), all the injector O-Rings, Fuel Filter, and map sensor. When the car is actually driving it drives fine and it drives smooth.
Oh and also if I have the A/C running then the car stops shaking and seems like it is idling fine. Not always will it do this but for the most part it does while the A/C is on..
Would anybody know what could possibly be causing this? I've been told by somebody else that they think it is my throttle body. Anybody else agree?? Trying to get some suggestions on what it could be. Please let me know.
Thanks
Old 10-07-2006, 02:29 AM
Re: 97 Cavalier 2.2 - Rough Idle
Hmm Anybody know what is going on? still no replys yet..
Old 10-07-2006, 03:02 AM
NJH_Habitatpro NJH_Habitatpro is offline
Send a message via AIM to NJH_Habitatpro Send a message via Yahoo to NJH_Habitatpro
Check the IAC The idle sensor, that and TPS thorttle position. Best of luck common problem that could have so many outcomes....
Old 10-07-2006, 10:04 AM
Blue Bowtie's Avatar
Registered Offender
I personally have had replacement injectors that flow at a different rate than the OEMs While the sequential fuel injection should be able to compensate to some extent for minor injector differences, significant differences in flow rates can cause exactly what you describe. It's usually best to either replace entire sets, or have the injectors tested and flow-matched. There are several services nationwide which perform this at a minimal cost, under $15 per injector.
Old 10-07-2006, 02:17 PM
Could somebody tell me where the "IAC The idle sensor" is located at on the vehicle? I know where the TPS sensor is located but not the IAC.
Old 10-08-2006, 03:58 PM
Anybody?? Also could somebody explain to me how I go about removing the fuel injectors.. I know how do remove them on a honda but it doesnt seem the same on this cavalier...
