Old 10-04-2006, 10:36 PM
GreyGoose006 GreyGoose006 is offline
is this right?
is this the way a stroked engine is created?
ignore my horible illustrations, you get the point.
seems logical to me...
note:
1 is stock
2 is "stroked"
not to scale
Old 10-05-2006, 09:58 AM
534BC 534BC is offline
Re: is this right?
Yes.
PS look out for skirt to counterwieght clearance. lol.
Old 10-05-2006, 02:47 PM
Re: is this right?
Originally Posted by GreyGoose006
Not to scale
like i said...
Old 10-05-2006, 03:12 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: is this right?
Yep, that's the exact concept. Often times the difference is only a 1/4" of stroke, so its often possible to keep the same rod length by moving the pin position up in the piston. Sometimes you can even add rod length to help counteract the additional side loads created by the longer crank.
You have the concept down exactly.
Dragging people kicking and screaming into the enlightenment.
Old 10-05-2006, 03:28 PM
curtis73's Avatar
Re: is this right?
Here is what I'm talking about with the stroker crank being able to use the same length rod. My drawings are kinda crappy too, but these both have the same length rod, just the pin is higher in the piston.
Old 10-05-2006, 03:56 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: is this right?
Makes me horny just looking at it.
Old 10-05-2006, 04:30 PM
Re: is this right?
i know you can do it that way, but it seems that it would interfere with the seals on the piston (rings maybe)
Old 10-05-2006, 04:33 PM
Re: is this right?
wouldnt a longer rod provide more levewrage tho?
if the pin is moved up, you have to make sure you dont have rod angles that are too high.
w/ a longer rod, it is easier (it seems) to keep rod angles in check
-edit:
shit, i meant shorter rod.
sorry
Old 10-05-2006, 04:36 PM
Re: is this right?
wait. never mind.
i'm confusing myself now.
ignore previous post
Old 10-05-2006, 07:53 PM
curtis73's Avatar
Re: is this right?
Yes, the longer rod can interfere with the rings, but you can cut the pins so that they don't interfere. The debate of longer vs. shorter rods has many sides and they both have their benefits. Longer rods have the benefit of a little more reliability and stability at high RPMs, but shorter rods can make a few extra hp.
Old 10-05-2006, 08:48 PM
Re: is this right?
is that due to the fact that a smaller lighter rod can rev higher?
Old 10-05-2006, 08:54 PM
Forunn Daberator
Re: is this right?
It has to do with rod/stroke ratio. If you do a little searching, as curtis said this is a never ending debate, most will agree (happily or not) that the "idea" r/s is 1.75ish.
