Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 10-02-2006, 12:56 PM
nostatic67 nostatic67 is offline
'98 power sliding door won't unlock
Does anyone have any experience with a 1998 passenger side power sliding door not unlocking? The solenoids sound and look like they are working as I see some rods/levers moving when I push the open/close switch. I also cannot manually slide the lock/unlock slider switch to the unlock position. I can get the door to open by pushing the open/close button and then manually pulling back on a horizontal bar on the inside of the door which I believe is attached to the locking mechanism.
Thanks,
Old 10-30-2006, 12:54 PM
Re: '98 power sliding door won't unlock
I adjusted a Torx T30 bolt 1/4" to the left on the locking mechanism which allowed the lock rod pin to slide into a channel and not hit the front of the channel. So far so good.
Old 08-01-2008, 11:35 PM
bluenose3 bluenose3 is offline
Hello I have an 03 Silhouette and had the same door lock problem on the passenger sliding door. Lock and unlock slider would not always unlock unless you pushed on a rod to the left of it. I did what you said and loosened the torx T30 bolt just above and the mechanism slid a bit to the left. Retightened it and it works beautiful. Thanks alot you saved me an expensive repair at the dealer
Old 08-02-2008, 12:11 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Good to hear you were able to fix the problem. In the future, please check the last post date in the thread and avoid posting in it if it is longer than 3 months from the current date.
Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
