Old 10-01-2006, 06:42 PM
agaylord agaylord is offline
Exclamation 98 Grand Prix Tach Problem
This is a rare occurance but its starting to weird me out. Sometimes when I'm driving, the tachometer will drop to zero and shortly after, the traction off light comes on. To fix this i put the car in neutral, turn it off, restart it, put it back in drive, and keep going. My car is a 98 Grand Prix GT with the 3800 series II engine. I'm guessing this is a computer problem but i have nooooo clue. any help would be awesome.
Old 10-02-2006, 05:51 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 98 Grand Prix Tach Problem
You have the classic symptoms of a crank position sensor going bad. It's located behind the harmonic balancer on the 3800 series-II.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-02-2006, 05:27 PM
is this the same reason why its starting to stall out at a red light?
Old 10-02-2006, 06:07 PM
BNaylor's Avatar
BNaylor BNaylor is offline
The crank position sensor generates 18X timing pulses to the ICM for the tach and ignition timing. Another classic symptom is engine stall out.
Timeslip 08/12/06
AF Community Guidelines
Old 10-02-2006, 06:42 PM
okay i had a free comp. diagnostic done just to be safe and it said the same thing. is this a fix i can do myself?
Old 10-02-2006, 07:57 PM
BNaylor's Avatar
It can be a DIY job. Sensor may cost around $50.00. See tech procedure in link below. Good luck.
Click here
Timeslip 08/12/06
