Old 10-01-2006, 10:31 AM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
How to do the boost bypass mod
whats up guys,i did search i do before i post anything but the thread i found with the link to how to do it was dead,any help ~joe......sorry guys just found it i tried to delete the thread like i could in the eclipse forum.
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 10-01-2006, 11:07 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: How to do the boost bypass mod
Yeah, the link has not been working for awhile now. I saved a text version but without pics. Click View Answer.
Here's the adjustment procedure less pics.
Boost Bypass Valve
(Picture: L67)
Tools Needed:
1 - 3/8 Drive Ratchet
1 - 3/8 Drive Small Extension
1 - 3/8 Drive 10mm Universal Socket
(Picture: Tools Needed)
Instructions:
Step 1: Locate hood release in driver side foot well. (Picture 1)
Step 2: Pull hood release toward you to pop the hood open. (Picture 2)
Step 3: Open hood by placing your hand between the hood and front bumper cover, making a left to right motion, catching the hood latch. (Picture 3)
Step 4: Raise hood. (Picture 15)
Step 5: Locate the Supercharger Boost Bypass Valve. It is the black cylindrical object to the left of the supercharger, above the front valve cover. (Picture 4 & then picture 5)
Step 6: Move the large set of wires aside from in front of the valve cover. They are held in place by a metal clip that is easily undone. (Picture 6 & then picture 7)
Step 7: Find the first 10mm nut, located just in front of the Bypass Valve, and loosen nut. DO NOT REMOVE! (Picture 8)
Step 8: Find the other two 10mm nuts; they are located BEHIND the Bypass Valve, on the supercharger housing. (Picture 9)
Step 9: Loosen these two 10mm nuts. DO NOT REMOVE! The first nut can be accessed from the left side of the Bypass Valve, the other one is a little trickier, and can be accessed from the right side. (Picture 10 & then pictures 11, and 12)
Step 10: Once all three nuts are loosened, gently apply pressure in a downward motion to the Bypass Valve. You will notice it may move as much as one-half inch. (Picture 13)
Step 11: While pushing down on the Bypass Valve, retighten the three nuts, in the order you loosened them. First the right side, then the left, and then the front. (Pictures 12, 11, 10, then 8)
Step 12: Re-clip the large set of wires back into the metal clip. (Pictures 7 & then 6)
Step 13: Close hood. (Picture 14 & then 15)
Notes:
Essentially what this free mod does is close the Supercharger’s Boost Bypass Valve sooner than set from the factory. This allows the boost to build quicker, this does not give you more boost. Since the Bypass Valve is not robotically set form the factory, it may be placed higher or lower for some, than others. Some people have noticed significant gains from it, and others have experienced nothing at all. I hope you had fun doing this mod, and hopefully you notice something. I had fun writing this, and taking all the new pictures!
Luan Zeqollari
2002 40th Anniversary GTP Coupe
13.72 @ 100.45 (Milan Dragway)
Everyone needs a refresher anyways.
Timeslip 08/12/06
AF Community Guidelines
Old 10-01-2006, 11:58 AM
BOSTONjoe98gs
i am having trouble finding it,i am new to this car maybe 3 days haha so i am a newb to this engine.is it in the back part of the engine or what cuz i found one thing that is cylinder and has a black clip on the top.
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
Old 10-01-2006, 12:18 PM
BNaylor's Avatar
It is located on the left hand side (drivers) of the supercharger, front. Click on View Answer below for pic.
Timeslip 08/12/06
Old 10-01-2006, 12:43 PM
BOSTONjoe98gs
ok i guess i have to remove that black thing but while i was trying i just sliced my finger pretty good,,how does that come off.edit ok i got that thing its patheticly easy..ok got all of the 3 bolts but one that hard one to get to my 10mil rachet must be a little stripped cuz i couldnt get a good set on that bolt,,no biggie i will try tomorrow.thanks for the help man. ~joe
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
Old 10-02-2006, 01:56 PM
BOSTONjoe98gs
ok,well i did that free mod.I can tell the difference,it definetly boost faster i seem to get full boost alot faster than before,well not alot but hey for a free mod ya cant beat it.thanks for the help bnaylor,ps i found a link with the pics in it.I tried to post it but when you click on it it brings you to the front page of the link.oh well later guys ~joe
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
