Old 09-03-2002, 01:27 AM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
Best Engine with Turbo set up??
I don't want a B motor. Not cause there bad or anything just cause i can't afford a b engine with a turbo kit. I have a 91hb std. what is the best engine and turbo set up. let me know.
:sun:
Old 09-03-2002, 01:35 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
can you afford an b18 non vtec? ls motor?
2002 Acura TL Type S
1991 Honda Crx Si
Old 09-03-2002, 01:36 AM
not sure how much do they go for? do i have to modyfi engine mounts?
Old 09-03-2002, 01:40 AM
im not sure but im pretty sure the b18 is the best engine to turbo not sure which one would work the best but the ls block is good so...i dunno check local junkyards
1991 Honda Crx Si
Old 09-03-2002, 01:57 AM
Any other engine set ups?
Old 09-03-2002, 02:02 AM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
check out the ZC... it is a direct bolt in and the 92-95 turbo kit will bolt on to it. this is the road im taking this winter. The ZC can be purchased for roughly $500. ut since you have a std civic it will take a little to get it up and running. however this is a great cheap engine to swap in. If you do the research on it the wiring modifications will be a breeze and the extra hp over the 1.5l you have now will definatley be fun to have.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 09-03-2002, 03:18 AM
toontowncivic's Avatar
toontowncivic toontowncivic is offline
check out a b16a1 they are pretty good they are a JDM 88-91 civic Sir engine. 160 horse vtec they are pretty sweet $ 1299 usd for everything you need!
Old 09-03-2002, 03:32 AM
Can i use neewer civic si motor?
Old 09-03-2002, 04:34 AM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
would people stop saying it costs 1300 for a b16a1 swap thats off b/c you need mounts a custom shift linkage and your gonna wanna replace worn items on the engine and put in a new cluch so your not looking at 1300 for a complete swap b/c you never know what your gonna get for your 1300
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 09-03-2002, 05:32 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah thats true, a shop installs it for around $3000. you will need an engine tranny ecu = $1200, motor mounts = $450, wiring harness $300, axles = $200, new clutch water pump timing belt = $400 so your looking at like $2600 for all the parts you need.
Old 09-03-2002, 08:31 AM
turbcivic's Avatar
turbcivic turbcivic is offline
i was looking at swapping the 5g d16 vtec into mine and turboing it out. Anybody think this is a bad idea?
Old 09-03-2002, 03:04 PM
if you want to run 10s eventually then yes its a bad idea. if you only wanna run like 13s then thats a good idea. but i think 13s or faster you should go b series
Old 09-03-2002, 03:12 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
I've heard that B18A with everything you need shouldn't cost more than $1000 or so. It's from the 90-91 ODB-0 Integras and is an easy swap.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 09-03-2002, 03:34 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
that is exactly why i am so scik of all the b series nazi's. outta flippin' control. you need axles, motor mounts, shiftlinkage, and a bunch of other garbage.
plain english...and yet how many people said....get a b series. WTF? am i the only one who listens to what people ask for? no matter what people say they want you say "get the b16". then i get e-mails saying "have any links on the b16 everybody says thats the engine to get" i give some links then the person comes back all bummed and discouraged because they found out it's too expensive (some how people "forget" to mention all the extra parts...they just mention $1000 for the engine) and it's waaaay to much work for them to swap in. sorry but if someone is in here asking what engine to go with...chance are they have NEVER swapped before and have no or a limited amount of tools.
for turbo info: stop by
here
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-03-2002, 03:39 PM
amy@af's Avatar
it is a great idea! sohc vtec $500+ECU $150+ harness $150=that's it.
you can build a d series turbo kit to run 10-14psi safely with no internal mods for around $1500 or get it all put together for you for around $2000.
check out the link i posted above
What's the Best clutch for my set up?????? 94civicvtecex '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 01-25-2006 07:55 PM
I need help with a turbo set up GT500916 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 11 10-25-2004 04:39 PM
Which Turbo Set Up for 03 Civic Si? jmnastee00civ Forced Induction 0 03-13-2004 12:41 AM
Best spring and shock set up Privatebigandrew Tires and Wheels 6 12-01-2003 09:45 PM
check out my turbo set up (pics inside) TatII 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 5 05-05-2003 06:40 PM
