Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 09-02-2002, 11:27 PM
blowngsr blowngsr is offline
Send a message via AIM to blowngsr
Unhappy jacksoncharger problems
I have a 2000 Integra GSR i have a JRSC on it. It used to run great. it ran 13.6@105 on street tires. then it has got slow. it is real boggy bottom end and it all the sudden hits about 75-80% power after 6 grand. also it detonates with any more than 8 degrees timing. my fuel pressure is good, my A/f is good, and my boost is all there (11psi). the only thing i remember before it got slow was i ran at the track w/ 112oct uleaded race gas. also i had the pressure switch relay swapped until i called jackson and got the right one. my air temp sens code is being thrown after 6 psi. i called jackson to get wiring schematics but they were not much help. no one can figure out what is wrong with my car. i have also done compression test. 3 cyl ranged from 155 to 165 psi and one was 185 psi. what is factory compression on a gsr? if any one has any suggestions please let me know. :flash: my car is slow please help i want to rape v-8's again!!!!!!!!!!
Old 09-03-2002, 03:50 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
Have you checked the cam/crankshaft alignment...?
One tooth off on any given cam, can cause up to an 18 degree change in timing. Since you can't take it up past 8 degrees, that sounds like whats happening to me....
The only other thing, is the O2 sensor took a hit when your ran the 112 octane.
You might do a search for a forum called "Forced Inducted Integra(s)", are something like that. I have not been there for awhile, tho....
Just some thoughts....
"Noth'in like Induction..."
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 09-03-2002, 05:36 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
One thing...In another thread on here you mentioned you didn't have an inter/aftercooler...Running 11 lbs?? Get one...Also, yes, check your O2s, 112 octane isn't good for them.
There's no replacement for displacement...No, not even a turbo.
Old 09-03-2002, 10:42 AM
the o2's are fine i have already checked them. but thank you for the suggestion. i will check to see if my cae is top dead center... im am pretty sure it is though.
Old 09-03-2002, 10:43 AM
does jackson make an intercooler for a gsr????
Old 09-06-2002, 09:46 AM
does any one know any east coast shops that specialize in JRSC?
Supercharger $2000, Destroying V-8's PRICELESS!!!!!!
00 GSR/JRSC/ICEMANCAI/DCHEADER/TESTPIPE/TANAUBEEXH/SKUNK2CAMGRS/street tires&11psi=13.6@105
Old 09-13-2002, 05:02 AM
Give JR a call and see what they have to say about any install shops. "Some" Honda dealers will install them. While others will stare at you like deer caught in headlights...
They should also be able to answer you Q's on the cooler, too...
They have had some bad PR, however with all the above mentioned probs I had. They were always there, or re-turned my phone calls anytime something was under question...
ZYDNE SECU, 450's
Old 09-13-2002, 09:25 AM
thank you, but i have come to the conclusion that i burnt up my piston rings. so now i am going to lower compression pistons so i can run more timing on the street, and it will be a lot more streetable... down the road a little bit maby sqeeze a little!?%*$
Thanks for the help.
Nissan Cefiro - Idling/driving rpm problem fnasir Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 10-01-2010 10:35 AM
01 Silverado Tranfer Problems kash1235 Silverado 0 04-14-2009 05:44 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
