Old 09-02-2002, 02:25 PM
EX'er EX'er is offline
What am i doin wrong??? (subs bottoming)
allright i just hooked up my stero in my 2000 civic ex and the dang subs are bottoming when i turn it on or off. It plays just fine after the horrendous sound of my sub half blowing. I'm using 4 gauge power and ground and mtx amp and JL subs with a line out converter and stock HU so whats up? I can't figure it out. Any one know??
Old 09-02-2002, 03:43 PM
b16a3sol b16a3sol is offline
mine do the same thing. supposedly what the problem is, there is still a pretty large charge in the amp when the car is turned off, but nowhere for it to go, so it is released into the sub. the way around this is to have the subs turn off before the HU turns off, so the charge is drained. as for when you turn the car on, i guess the same thing should still work, but i dont know.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 09-02-2002, 03:46 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
yep, you have the infamous turn-on/off thump. It's the fault of the amp - try wiring the remote turn on to a switch, and see what causes the least noise - turning on/off the amp before/after the stereo
Old 09-02-2002, 04:08 PM
so your sayin throw a 12 volt switch on my remote line and the problem should disapate.............i'll give it a try............thanks
Old 09-02-2002, 10:22 PM
Audio Guy
yea, hook one side of the switch to constant 12V and the other side to the remote wire you already have run to the amp. It will give you the opportunity to turn the amp on/off independent of the stereo.
What does reverse sub do on Pioneer 8400MP? Devedander Car Audio 9 04-22-2002 10:47 PM
OMFG!!! What is wrong with this??? Kabs '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 35 12-12-2001 06:40 AM
What is wrong with these people? Geez! NismoPC General 30 10-30-2001 10:20 AM
What is wrong with my paint job? Ron Ketcham Engineering/ Technical 9 03-25-2001 04:25 PM
