Old 04-17-2002, 01:27 AM
Devedander Devedander is offline
What does reverse sub do on Pioneer 8400MP?
I read the manual and I Can't figure out what the revers option does on the subs. It shows the sub pointing down instead of up when I choose it but it sounds pretty much the same, different but I can't quite call what it is.
Also anyone konw how ASL works on these puppies? I turned it on and it does adjust my volume for me as the car gets noisier but I don't get how it can tell how noisey my car is.
Thanks.
Old 04-17-2002, 01:40 AM
xivera's Avatar
xivera xivera is offline
I think the "reverse sub" option changes the phase [angle] of the sub. It's basically like manually changing the polarity of the wires (+'ve/-'ve). Sometimes, some subs may sound better by using this.
Recently, I have played with my phase. It sounds better now...
ASL: The idea is to set it so that when changing between sources there is no shockingly amount change in volume. (Mine is adjustable.)
I/H/E, I.C.E. & other stuff...
Toni/y v0.2|Nice cars thru my lens...
Your first mod = HELMS MANUAL!!!
Old 04-17-2002, 01:55 AM
Is it bad for subs to be played in reverse? Wouldn't it be bad to hook up pos to neg and vice versa?
Also in my manual the description of ASL is that as you drive road noise and backgroudn noise can get in the way, ASL will automatically adjust volume to compensate.
Old 04-17-2002, 02:20 AM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
No to first question, "yes" to second...
First, + and - are not the same like on a battery. On a subwoofer, this only gives you instructions on how to connect the woofer for the proper ohm load and such. Since a "voice coil" is just that, a SINGLE coil with ONE starting point which continues, wraps around the "pole" piece and then out the other end (negative) this just tells you how to hook it up for normal phase... when you reverse this, you simple send power up the other direction -- not harmfull to your woofer. This is known as out of phase... you usually do this in subwoofer setups where one woofer is mounted normally, and then another woofer is mounted inverted and then wired "out of phase" to match it upto the other woofer...
ASL will increase radio volume as road noise increases.... jump on the highway, going 80 mph... its differant then cruising a city street at 35... personally this is a "lazy man" feature -- never liked it.
AF's Official Asshole
RIP AUNIE
Old 04-17-2002, 08:45 AM
iLLuCiv99's Avatar
iLLuCiv99 iLLuCiv99 is offline
Send a message via AIM to iLLuCiv99
Hey wait I think it's time once again for...
Originally posted by crxlvr
sparq got it right again
J+L
Old 04-17-2002, 10:55 AM
xivera's Avatar
Hmmm... I guess mine is different...
Old 04-18-2002, 12:18 AM
Xivera I think yours is SLA or something not ASL cuz mine has that too, so I can set different gain levels for AM, FM and CD. I just wondered how the ASL knows how lound things are, is there a little mic or something?
Thanks for your answers though.
Old 04-18-2002, 12:28 AM
xivera's Avatar
Oh... yeah, that's right! Damn, that ASL must be pretty cool then! (Perhaps, I need an upgrade! )
At any rate, it probably uses some sort of sensor/mic...
Old 04-22-2002, 05:08 PM
-=BOOMER=-'s Avatar
-=BOOMER=- -=BOOMER=- is offline
Send a message via ICQ to -=BOOMER=- Send a message via AIM to -=BOOMER=- Send a message via MSN to -=BOOMER=- Send a message via Yahoo to -=BOOMER=-
One other thing is that you can run a sub out of phase if it is far from where the rest of the system is, it will cause the sub to fire a little quicker or a little later depending on your choice. It helps if your subs dont sound right or a little slow in a system. prity much your trying to match when the wave of the midbase/highs hits your ear to be the same time that the wave of bass hits your ear. alot of times people mount there subs facing backwards, it helps well in those situations because the bass has to go to the back of the car and then "bounce" back to the front of the car. they do that so the wave of bass has more time to develop but it also has the tendency to slow down the arival time.
Old 04-22-2002, 10:47 PM
Well I do face mine backwards so I will do more playing around with the reverse.
Whats better Alpine or Pioneer?? tonka_p Car Audio 6 12-15-2006 03:52 PM
Does Reverse gear require electronics to work? fixitman111 Caravan | Voyager 2 07-27-2006 06:16 PM
Reverse Subs ViperJ Car Audio 32 12-22-2005 06:30 AM
what does (2 ohm + 2 ohm) mean for subs? 97mntecrlo Car Audio 1 04-12-2004 07:41 PM
how does a twin or single turbo work and what does it do? bullseye Engineering/ Technical 4 05-05-2003 08:18 PM
