Old 09-01-2002, 05:49 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Burning oil
My car is burning oil like a bitch, smokes just pours out of the exaust, i think its the head gasket.........anyone else have a suggestion on what it could be?
2002 Acura TL Type S
1991 Honda Crx Si
Old 09-01-2002, 06:13 PM
88hondaowner 88hondaowner is offline
Banned
Send a message via MSN to 88hondaowner Send a message via Yahoo to 88hondaowner
hey i just had the same problem. my deal was the valve cover gasket..the oring around the distributor and some other gasket. so check those.
Old 09-01-2002, 06:16 PM
yeah but i think its mainly the head gasket cus antifreeze and water is coming out the back too.....it was when i was flushing out the system anyway
1991 Honda Crx Si
Old 09-01-2002, 08:10 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Sounds like a head gasket, but while you have it open pull the pistons and ring it too.Oil is getting past the rings to get burnt in and make smoke...... save you a big headache if you replaced headgasket and it still smoked......
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 09-01-2002, 08:12 PM
thanx for the info
1991 Honda Crx Si
Old 09-02-2002, 12:29 AM
optimuspeterson optimuspeterson is offline
Send a message via AIM to optimuspeterson
do a compression test. you can buy the tester for like 30 bucks.
do the test and figure out what the numbers are (make sure the engine is warmed up). Then do a second test but before you do it add a tee spoon to each cylinder before you test and if the compression goes up then most likely its your piston rings or pistons. if it doesn't go up then its more likely your HG.
http://home.bendcable.com/optimuspeterson/ <<<<HRC Stage 2 and Star Instructions
95 GS
Mods: Probably a whole lot more than you.
Old 09-02-2002, 12:51 AM
uhh ill just get a new head gasket......probably could use a new one anyway with 183,000 miles on it
1991 Honda Crx Si
Old 09-02-2002, 03:28 AM
habib_88's Avatar
habib_88 habib_88 is offline
Unhappy
I have 161k on the clock now...this winter I decided I needed a head rebuild. I can't keep my engine block clean it will just ever so slighty cover with oil again after about driving for a week. I figure i'll get all new head seals and a new head gasket and I should be good to go. I've already done my valve cover and distrubtor gasket so i'm running outta things that are easy to replace at this point. But I'm told at this milage its pretty expected, still gotta give honda credit they built one heck of a little motor for goin this long hehe.
89 Si #77 and now with 2003 STS winnAr mod!
LadyNRedSi: the integra is a spotless cow
habibswd: i'd sooooo milk a spotless cow
...wow that was a old conversation
Old 09-02-2002, 02:16 PM
yeah my dad has 234,000 on the clock and i drive that car alot too and my car has alot of kick for 183,000 on it i can still hang with alot of cars on the road
1991 Honda Crx Si
Burning oil at idle bhw33191 Caprice 20 09-13-2009 02:43 PM
smoking from the oil filler cap, dipstick and exhaust jimgbgt MGB 2 07-24-2009 05:26 AM
burning oil after oil change wtijr Regal 18 09-08-2008 10:47 AM
burning oil, which oil is best? street hawk Intrigue 7 05-04-2006 03:32 PM
Burning oil after switching to synthetic oil RedRacerCivic '88 - '91 Civic | CRX | Wagon | Shuttlee 7 01-20-2003 08:50 PM
