Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 09-25-2006, 10:35 AM
SPERAON SPERAON is offline
Need to know how to pull the axle assembly
I have a 1991 Honda Prelude SI, the axle assembly was damaged in an accident and I need to pull the inner shaft from the Transmition, Is there a tool or a trick of the trade to get this out?
Ive got all the axle out except the shaft that is in the transmission, Ive used big screw drivers, now trying a crow bar, its out about 1/4inch but does not want to come out. Im thinking I need to take out the other axle and tap it out from the other side.
Old 09-25-2006, 05:58 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Need to know how to pull the axle assembly
The axle itself just pops out of the transmission. While I'm not too familiar with preludes, to replace it you'll have to remove the axle nut from the end and probably unbolt the lower shock fork and seperate the lower balljoint.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 10-08-2006, 09:45 AM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
yeah i agree with audio guy. i took mine out of my hatch yesterday and after i freed the ball joint just took a flathead screwdriver and put it between the axle and tranny. should just pop right out.
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
