Old 09-24-2006, 07:50 AM
jimbo58 jimbo58 is offline
astro ac recycling problem problem
Hi my first time posting I have a problem with my 95 astro which appears to keep recycling when ac is on,have changed low pressure switch but no joy any ideas would be much appreciated
Old 09-24-2006, 09:10 AM
Blue Bowtie's Avatar
Registered Offender
Re: astro ac recycling problem problem
If the low pressure switch is working properly, and the system is properly charged, the compressor might recycle if there is clogging in the expansion control (orifice tube) or if the ambient temperature is low enough to reduce the evaporation rate of the cold liquid.
Old 09-24-2006, 09:21 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Pressure switch or wiring or low on 134-A or improper pressure will do it.
Just for a test. If a two wire plugin switch.
Jumper the low pressure switch and wiggle the wiring plugin and see if it will stay running.
But we need a low and high side pressure reading with the compressure running at idle and at 2000 rpm to help.
With one of these.
http://www.ackits.com/merchant2/merc...uct_Code=66773
Post back pressure readings.
MT
MT
Old 09-24-2006, 10:50 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
With one of these.
MT
Harbor Freight Tools has one on sale for $30 now check this link out too: http://www.harborfreight.com/cpi/cta...emnumber=92649
