Old 08-31-2002, 09:43 PM
mightytexn's Avatar
mightytexn mightytexn is offline
Send a message via AIM to mightytexn
17's
What size tires should I have so my speedo still reads correctly if I put 17's on my car? The closest I can find so far is 205/40R17 and it says that my speedo will say 57.9 when I'm going 60. That shouldn't be too much of a problem if that's as close as I can get, but I would like it to be as accurate as possible.
Old 09-01-2002, 01:34 AM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
It's usually not a problem.
just keep pace with the traffic.
and if there are pigs around go a little slower than the posted speed limit.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 09-02-2002, 01:13 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Peep this.
http://www.miata.net/garage/tirecalc.html
Assuming your stock tire size is 175/70/R13, you would want to go with 205/35/17's and your spedometer would be spot on.
Personally I wouldnt want my profiles that thin, and I dont even think they make those, so I would probably go with 195/40/R17's and have my speedo be 2.2% too slow so if the speedo said 60 I would really be going 61.3mph
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 09-02-2002, 01:58 AM
mightytexn's Avatar
Thanks Melt. I don't really want that low pro tires either, but the rims I want only come in 17" or 18", so I guess I'll just have to go with a speedo thats not quite right.
Old 09-02-2002, 03:31 AM
If you go with a 17"x7" rim your recomended tire size would be a 205/40/17 if you go with a 18"x7" you will need to use a 205/35/18.
just thought i'd let you know.
||JEFF| |
Old 09-02-2002, 03:36 AM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
yep thats what i got on my 17's and it looks good not to thin at all
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 09-04-2002, 01:34 AM
91civicDXdude's Avatar
i didnt realize they made 35 series 17s. i thougth the smallest you could get was 205/40
Old 09-04-2002, 05:56 PM
they make absolutly everything these days!
here's an example.
Say you want a set of rims....but the rims dont come in the propor bolt pattern for your car.....let me know I can have them custom made straight from the factory to fit your car
||JEFF| |
offset of 17's tsunamiHB Tires and Wheels 3 12-18-2001 12:16 PM
Anyone got 17's without lowering? Cue-Ball General 4 12-16-2001 01:49 AM
18's vs 17's GiNO805 Suspension 22 09-30-2001 05:56 PM
