Old 08-31-2002, 08:45 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
ECU codes up the wazoo
so my chek engine light comes on the other day right.....and i just got time to look at it today.... and the LED was blinking up a storm. I have: code 1, code 9, code 16, and code 20...... code 1 is the oxygen content, does this mean that my o2 sensor has gone bad? code 9 is No. 1 cylinder position, uhh what the hell is that? code 16 is Fuel injector, uhh the hell is that? and code 20 is Electric Load, uhh what the hell is that? now my car runs fine... its doesnt feel like anything is wrong. can some one please help me with these codes and how to fix them. thank you.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 08-31-2002, 09:40 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Try re-setting your ECU and see if the codes come up again.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 08-31-2002, 10:08 PM
91zc 91zc is offline
Code1= Oxygen Sensor is not working properly
Code 9= Crank angle sensor inside the distributor
Code 16= Fuel Injector might be faulty?
Code 20= THe most fun one of all...something is overloading the cars electrical system. It is hard to track down but with persistance you should be able to correct it.
As Marc said try resetting the ecu and see if they are thrown again.
91 civic 4dr
b16a
14.8@94
Old 08-31-2002, 10:53 PM
i'll try that and see what happens..... i'll keep ya posted.
Old 08-31-2002, 10:55 PM
mdnnccivicrcr mdnnccivicrcr is offline
stupid question... how do you reset the ECU?
90 Civic EX *RIP*
90 CRX DX *RIP*
88 Civic DX Sedan (pushing boost) *RIP*
95 Accord LX Sedan
Old 08-31-2002, 10:58 PM
pull the fuse marked "ECU" in the fuse panel under the hood for like 10 seconds.
Old 09-01-2002, 06:48 PM
daddys's Avatar
daddys daddys is offline
i thought it was the hazard fuse
Old 09-01-2002, 07:57 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
or disconnecting the battery...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 09-01-2002, 08:32 PM
gunnmen01
no that doesn't work. and your are correct it is the hazard fuse not the ecu fuse....
Old 09-01-2002, 08:37 PM
but anyways....i figurd out the problem. as i was reseting my ecu i looked over an noticed that the cam senor on my second cam was unpluged....so i plugged it in and poof....the code yet away.
Old 09-02-2002, 12:24 AM
optimuspeterson optimuspeterson is offline
Send a message via AIM to optimuspeterson
lucky him, he got to clear his codes only to come over and help me drop my tranny. oh well it was easy as shit to do.
http://home.bendcable.com/optimuspeterson/ <<<<HRC Stage 2 and Star Instructions
95 GS
Mods: Probably a whole lot more than you.
Old 09-02-2002, 01:20 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Sup g, hows the eclipse?
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 09-02-2002, 12:08 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
what distro did you use? are you just getting a code 9 now? or the others pop back up?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Flash ECU, will the car start without? schreib Rodeo | Passport | MU 1 03-15-2010 09:09 PM
Alarms out the wazoo Txsbigfoot Titan 2 02-26-2006 07:32 PM
how do i read the ecu code? viridion Technical 1 10-20-2005 01:28 PM
Where are the ecu codes KradCRX90 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 02-11-2005 10:22 AM
ECU codes barrlucas Maintenance 3 08-12-2001 01:32 PM
