Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-21-2006, 08:58 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I'm an idiot.
Moral of the story - check that IGN-ECM fuse when your ECM "fails".
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-21-2006, 10:50 PM
capriceowns capriceowns is offline
Re: I'm an idiot.
you didnt buy another one did you?!
1987 Chevrolet Caprice classic Brougham. 142,000 on the 305 and still chugging
Old 09-22-2006, 01:41 AM
silicon212's Avatar
Confoundingly Lucid
Re: I'm an idiot.
Why yes, yes I did ... but it's going back. It was only $79, but I need all the money I can get with my job.
Old 09-22-2006, 05:37 AM
CD Smalley CD Smalley is offline
Re: I'm an idiot.
Dude that sucks. I've done things like that too. Happens to the best of us.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 09-22-2006, 12:46 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: I'm an idiot.
We learn from our mistakes. As the saying goes,(when trying to diagnose/fix a problem), "Always start with the simplest or cheapest part."
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 09-22-2006, 12:58 PM
Re: I'm an idiot.
This reminds me back when I had a powersteering leak, I right away ordered a new low pressure line, when all I needed was 2$ fuel line with a bend in it and a fitting on the end to screw in and some rubber hose
Returning items rocks!
Old 09-22-2006, 01:42 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: I'm an idiot.
Bad part is, it makes you feel twice as bad when people are always turning to you for advice.
It's so easy sometimes to think outside of the box and overlook the little things.
I'll bet you porbably had the same sinister, "ah hah you little S.o.b." snicker when you found it
Old 09-22-2006, 02:57 PM
silicon212's Avatar
Confoundingly Lucid
Re: I'm an idiot.
It was more like "Oh, that explains it" ... The problem is that I think like a technician, so I pulled out the diagram I had for it, which omitted that fuse from the diagram. Only seeing two fuses, GAUGES and ECM, I checked those two fuses and they were good. It wasn't until I was probing around in there last night that I stumbled upon the IGN-ECM fuse. I pulled it and looked at it, and saw it was blown. Perhaps I shouldn't always think like a tech. I suppose if I thought like a 5-year-old, I would have found it immediately.
But you're right - I give a lot of advice here and then _I_ go and pull a stupido.
Old 09-22-2006, 03:06 PM
Re: I'm an idiot.
We still wuv you!!!
Old 09-24-2006, 09:40 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: I'm an idiot.
that one of those owned moments!
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 09-24-2006, 01:34 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: I'm an idiot.
don't feel too bad.
there was a guy on here who replaced his WHOLE engine when he had a blown head gasket.
Seatbelts Saved My Life
Old 09-24-2006, 01:53 PM
silicon212's Avatar
Confoundingly Lucid
Re: I'm an idiot.
Originally Posted by 2.2 Straight six
don't feel too bad.
I did that once ...
the affected head was warped, and the block between 3 and 5 was burned through. Had no choice but to replace the whole thing. This was a Poncho 400 in a '75 Grand Am. Thanks, sis!
That was in 1993. The engine that replaced the 400 was a certain SBC 350. The same engine in the Caprice, now - some 263,000 miles later.
Old 09-25-2006, 04:42 PM
1986Z28's Avatar
Has a Camaro
Re: I'm an idiot.
ha. small block chevy just wont die will they
