Old 09-20-2006, 09:04 PM
MooseNelson's Avatar
MooseNelson MooseNelson is offline
Plate in front of rotors - how to get it off
This is kind of a general question, sorry had to repost here!
This Eagle I bought is in need of serious brake job, replacing rotors front and back.
Finally got the right socket for axel nut 32mm, but I'm stuck getting off the plate that's in front of the rotor. I assume it's just stuck on there and in need of a serious whacking, but any help here? see pics:
THANKSS!
Old 09-20-2006, 09:15 PM
nickb2 nickb2 is offline
Re: Plate in front of rotors - how to get it off
This hub has to be pulled off with a hub puller....and then pressed back on...takes a hub puller tool. if you need more info let me know
Nick
ASE Master Auto Technician, L1
Old 09-21-2006, 01:39 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Originally Posted by MooseNelson
= I assume it's just stuck on there.....
Yip, along with the bearings and rest of the hub casting.
The rotor is then bolted to the back of it.
If it won't come off easily, then as stated above you need a hub/pully puller to gently pull it off.
Whacking it with hammer might not be the best idea, unless its a "controlled" tap with a proper soft mallet to the back of the disc.
Old 09-21-2006, 07:30 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Typical Mitsubishi/chrysler backasswards engineering.
Old 09-21-2006, 09:00 AM
GreyGoose006 GreyGoose006 is offline
why do they do that...
it must be easier, but it would make more sense for it to be fixed in place some other way. they are just requiring people to buy extra tools to do their own repairs.
i guess thats what we get
Old 09-21-2006, 03:08 PM
UncleBob UncleBob is offline
AF -Advisor
lot more manufacturers did that than just those two.
Dare I say, over the years, all of them have been guilty at one point or another.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 09-22-2006, 04:15 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
hub puller.
Seatbelts Saved My Life
Old 09-25-2006, 01:18 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Its not necessarily bassackwards, but it is a pain. Many of those hub assemblies are a press-fit bearing which work very well as far as reliability, but make brake jobs a pain. I have a truck axle that requires complete removal of the axle shafts to pull the drums
Dragging people kicking and screaming into the enlightenment.
Old 09-25-2006, 04:19 AM
KiwiBacon KiwiBacon is offline
Damn, that's almost the same as my rangerover setup.
Of course with a rover you've got oil bath wheelbearings and two locknuts to deal with instead of needing a wheelpuller.
