Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 09-20-2006, 08:40 PM
tukker tukker is offline
won't start
Last night I started my 2.8 and it ran fine until I believe it ran out of fuel. since then it has not started and i have no spark either
please help!
Old 09-21-2006, 06:22 AM
musclecarfan6's Avatar
musclecarfan6 musclecarfan6 is offline
Re: won't start
running it out of gas maybe burned the fuel pump. Check for fuel pressure.
95 Plymouth Neon 2Door 2.0L SOHC
89 Buick Century Custom 3.3L
____________________________
What to see pics of my cars. Go
to www.cardomain.com and look
for musclecarfan6. Rate or leave
comments if you want.
Old 09-22-2006, 08:32 AM
Blue Bowtie's Avatar
Registered Offender
Re: won't start
What year? How are you testing for spark?
Old 09-23-2006, 08:21 PM
Re: won't start
I think i may have figured it out i believe when i had the motor still being held by the lift it ran great but when i set it down and fastened my motor mounts thats when it did'nt start so i lifted it back out and low and behold the crankshaft positioning sensor wires were cut from the motor mount. I fixed that and hopefully when i put it back in everything is ok.
It is a 1989 beretta gt manual 5 speed , the motor came out of a same year beretta
Old 09-25-2006, 04:43 PM
Re: won't start
niope that wasn't it. any other ideas?
Old 09-26-2006, 12:53 PM
jdl jdl is offline
Re: won't start
With the vehicle cranking, do you have an injector pulse? Do you have spark? Is there a tach signal when you crank the vehicle? On a lot of these type vehicles there is a purple wire with a white tracer, goes from the ignition module to the computer, carries the rpm signal. No signal and the vehicle won't start.
Old 10-08-2006, 09:26 PM
Decipha Decipha is offline
Re: won't start
LMK how it goes tukker... i may be able to help out some PM me if needed
