Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 09-20-2006, 10:18 AM
element51 element51 is offline
93 del sol Check engine light
OK, i did the jump and got a code for the oxygen sensor. Now in my understanding, there is a pre-cat and a post-cat sensor. Which one is it?
EDIT: It's Code 1
Old 09-20-2006, 03:32 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: 93 del sol Check engine light
The O2 is located before the cat. Check for voltage between terminals A and B (top two terminals comming from the sensor.) The sensor should produce .1v when the engine is cold and fluctuate between .1 and .9 when the engine is at operating temp. If the sensor doesn't do this, replace it.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
