Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-18-2006, 06:26 PM
deeders78 deeders78 is offline
305 chevy engine problem
I have already changed the valve seals on my engine. And my engine keeps smoking. Any suggestions to what else the problem could be on why it is still smoking? I am not loosing any engine compression. Please somebody help!
Old 09-18-2006, 09:24 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: 305 chevy engine problem
how manny miles? did you replace the intake and exhaust seals?
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 09-18-2006, 09:33 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
what color smoke, btw this is the performance section!
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 09-18-2006, 10:00 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Oil smoke will be a whitish-bluish color. If you're trying to T-shoot the source of the consumption, general rules indicate:
If the smoke occurs when you first start the engine, then clears up, that's an indication of leaky valve guide seals. If it smokes when it starts up, and when you're decelerating, that's an indication of worn guides. If you smell smoke when you're cruising or decelerating, but you don't see any, that could be a leaking intake manifold gasket (drawing oil in from the lifter valley).
If the smoke occurs when you accelerate, but generally does not occur on first startup, or it does but does not stop, that's an indication of worn piston rings. It could also be an indication of internal engine damage (broken or cracked piston, cylinder wall scoring, etc).
If the smoke is grayish to grayish black, to pure black, that's an indication of a rich fuel condition.
If the smoke is white, it could be a bad vacuum modulator (TH350/400 only) or engine coolant (cracked block, blown head gasket, warped head, cracked head, etc).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-20-2006, 06:25 PM
Ok...the smoke coming out of the exhaust is whitish blue. It smokes when i start it ...then tapers off but still lightly smokes. Also smokes really bad when accelerating after a dead stop then tapers off again but still lightly smoking. Perhaps thats a little more specific. Any more suggestions? Thanks for your info. I'll take any help I can get!
Dee
Old 09-21-2006, 09:05 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
From that, I gather it's either improperly installed guides/keepers, worn rings or a stuck open PCV valve (which would be nice)
Old 09-26-2006, 02:29 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
I was under the impression that white smoke = coolant...
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 09-26-2006, 08:41 AM
wrightz28's Avatar
Yes, but he stetes whitish blue
Old 03-10-2014, 04:31 AM
ballinalling ballinalling is offline
Egr valve or PVC my 84 Monte smoked so bad it wasn't guide seals like we thought.
