Old 09-18-2006, 10:25 AM
mobileking mobileking is offline
Don't overfill your fuel tank
Can anyone tell me what have written in this blog is true ?
http://overfillfueltank.blogspot.com/
Thanks
Old 09-18-2006, 12:08 PM
bluevp00's Avatar
bluevp00 bluevp00 is offline
Re: Don't overfill your fuel tank
Pretty much all true, thats why fuel stations have warning signs that say "Do not top off", for exactly those reasons.
Old 09-18-2006, 02:37 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
#4 is about the only one with any real basis.
Old 09-18-2006, 04:47 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Let me guess, blogs are now considered accurate sources of reliable information?
Its all a crock of shit.
Old 09-18-2006, 08:23 PM
GreyGoose006 GreyGoose006 is offline
mine clicks off if i fill it too fast. i cant just set it on the clicks and walk away. i have to hold it half open. if i set it and leave, it will click off a dozen times or so before the tank is full. ( i know this because i go in with an empty 26 gallon tank and it clicks off after 10 seconds for all those out there who will argue that i am overfilling)
Old 09-18-2006, 10:56 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
The technical info was somewhat jumbled and misleading.
However, the basic message is good for the general public who know nothing and care even less about cars and how the work. For them, the advice is probably good.
Old 09-25-2006, 02:28 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
The main problem with topping off your tank is that the evap hoses can become covered with liquid fuel. The evap system takes excess vapors from the tank and introduces them into the intake instead of venting them to the atmosphere. If you top off the tank it can introduce liquid fuel to the charcoal canister which is only designed to handle vapors.
The problem I have is that every fuel pump is adjusted differently. Sometimes you can top it off five or six times and other times a pump will spit fuel back at you on the first click. Its also widely variable based on the fuel tank. My 73 station wagon's fuel cap is literally a hole in the top of the tank, while my previous 87 BMW had at least 4 feet of hose that led to the tank.
I say, let the pump click and leave it alone... except with diesel. It tends to foam up making the pump click too soon, and most diesels don't have evap systems anyway.
Dragging people kicking and screaming into the enlightenment.
Old 09-25-2006, 05:14 AM
KiwiBacon KiwiBacon is offline
Something changed in the diesel fuel mix here about four years ago. Diesel didn't used to foam and getting a full tank was never a problem.
But now each year the diesel gets frothier and frothier.
Old 09-25-2006, 11:04 PM
cody_e cody_e is offline
Send a message via AIM to cody_e Send a message via MSN to cody_e Send a message via Yahoo to cody_e
Sometimes the noddles become bad and then it clicks at like 2 gallons in when you're filling form a 1/4 tank. That clicker thing isn't the best to go by.
Old 09-25-2006, 11:09 PM
Moppie's Avatar
Master Connector
I spent 5 years pumping gas from 95-2000, then 4 years driving trucks from 2000-2004. I still drive the odd truck when needed, and so still fill the odd tank with diesel. It would be fair to say Iv pumped more fuel than the average person
IMO the amount of froth hasn't changed one single bit.
Altough fuel tank and filler design can have a large infulence on how much the froth there is.
Old 09-25-2006, 11:20 PM
Forunn Daberator
Every time I run dishwashing liquid though my tank to clean the injectors, I get froth for the next few fillups.
(sorry, I couldnt resist)
Old 09-25-2006, 11:32 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
i have to agree.
over here, you just can't keep clicking it. there comes a point where it won't click anymore, you click it 3-4 times and that's it, it refuses to put any more in. of course you can position the nozzle in such a way that the vacuum valve allows you to pump away, but then you find fuel pouring out of the filler and down the side of your car.
many trucks here use special "filler inserts" which is like a machined steel "cage" so a hose can't but put into the tank in order to drain it and steal the fuel.
Seatbelts Saved My Life
Old 09-26-2006, 01:24 AM
Oh well I'll put that down to alzheimers then.
Old 09-26-2006, 02:08 AM
its especially bad if the orientation of the filler nozzle is in the "more-downwardly" position than it would be if you were facing the car the other way on the slight hill at all pumps...
(i really hope that made sense)
i think it has something to do with the fact that when the filler neck fills up with gas because you are pumping too fast (pervert), facing down hill, or the neck has been kinked, ect... it clicks off. once the gas has settled down and is not all 'bunched up' in the filler neck, things go just fine (in my experience)
usually for me, this results in obscenely long fillups, as i have to sit there and hold the stupid lever so that gas is noly coming out at about half speed (i do have a 26.5 gallon tank tho)
Old 09-26-2006, 06:34 PM
89Sunbird 89Sunbird is offline
I once heard it click, and at previous times with the gas station, it would click off if it was close, but too fast. So I kept popping it, it kept clicking. I finally looked over and saw all this gas running down the side of the Jeep. whoops.
