Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 09-16-2006, 01:15 PM
mithomas48 mithomas48 is offline
Blower Motor Stuck On
Hi everyone!
My 1998 concorde (3.2 liter) has the heater blower motor stuck on. It blows heat all the time. I have a digital climate control module and it will not shut the blower motor or heater off. When pressing "Auto" the a/c compressor will engage and pressing "Off" it goes off, but the fan and heater stay on. The temp control seems to be working. If I turn it up the air gets hotter. If I turn it down the air gets a bit cooler. It seems like both the a/c and heater are on. The buttons that control the air flow are working. The knob that adjusts the fan blower speed has no affect at all. When I unplugged the control module the fan motor still continued to run.
Does anyone have any ideas or experience with this type of situation? Thanks in advance for your help!
Mike
Old 09-17-2006, 08:59 AM
jdl jdl is offline
Re: Blower Motor Stuck On
You can go to the local auto store and get a repair manual for your vehicle, if you don't have one, the wiring diagrams might help you, to understand the system.
Right now, I would probably pull the electrical connector for the blower. You might be able to just pull a fuse. By killing the circuit, it might allow something to reset, then it might work normal. I don't usually get that lucky, though.
Some automatic temp control systems have their own diagnostics, with obd11 you might need a manufacturers scanner to get the info. OBD1 usually you could press a couple of buttons on the control module, to get info.
If you don't get an answer you like here, you might try allpar.com, that is a Dodge--Chrysler--Plymouth site, they have Q&A forums.
Old 09-23-2006, 07:34 PM
PlatinumMOTO PlatinumMOTO is offline
Do you have Automatic Temperature Contorl if so your ATC module is bad.
Old 03-31-2007, 02:12 PM
Thanks for the reply. I have replaced my ATC module and the temperature is working ok now. However, the fan motor is still staying on and is not being controlled by the ATC module (even when turning the manual fan speed control).
Can someone please help me with determining the cause?
Thanks so much in advance!
Mike
Old 03-31-2007, 02:32 PM
Scrapper Scrapper is offline
AF Premium User
if not module i'd see if you could get to the switch unhook it or pull the fuse and go to advanced or autozone to get a hanes maual for that car.good luck.....
Old 03-31-2007, 07:11 PM
Thanks again for the reply. The fan goes off if I pull the fuse. When I start the car, the fan starts running with no climate control. When I turn the ATC on I can adjust the temperature ok (a/c or heat). It has to be something outside of the ATC module. What would keep the fan turned on?
Thanks again!
Mike
Old 04-09-2007, 11:13 AM
farmngmom farmngmom is offline
Same thing happened on both my son's '94 and '95 Concorde's. On one it was the ATC and on the other is was a bad motor speed controller (or Fan Blower Motor Resistor.) Got a rebuilt one for $49.99 at the following link. He also does rebuilt Cliamte Control. I got the info from someone else on this forum. He goes through Ebay and I did a search for a Climate Control and a fan blower and then went to his web site from there but then called him and ordered the parts rather than going through Ebay. He was also very good about talking to my son on the phone while he was replacing it, explaining where the part was and walking him through the procedure to replace it.
http://search.stores.ebay.com/SPEEDO...796228QQsofpZ0
Old 04-14-2007, 11:26 AM
Just wanted to say thanks to everyone. Sue, I will follow up with the web site you shared and call them this week. Thanks so much in advance for your help.
Mike
