Old 09-14-2006, 08:07 PM
jgwardle jgwardle is offline
99 LeSabre Fuel Pump
have 99 lesabre fuel pump making loud humming noise while running does it need replaced or is there another problem ?
Old 09-14-2006, 08:10 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: replacing the fuel pump
Your post has been moved from Regal to LeSabre.
Welcome to AF.
Timeslip 08/12/06
AF Community Guidelines
Old 09-14-2006, 09:26 PM
Andrewhuffman Andrewhuffman is offline
Re: 99 LeSabre Fuel Pump
a loud humm means your pump is about to burn out. i ahd mine humm for over a year and it still didnt go out, but i changed it bacause i have problem, and the fuel pump wast though to be it, didnt help. recomendation is to drive for as long as you can and wait for it yo stop. unless you abosoulty hate the nois or dont waht to get stranded, but there no telling how long it will last, possibly last for years. or you would change t if you had extra money to spend.
Old 09-14-2006, 09:43 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Welcome on your first post on AF.
First thing check that fuel filter.
It may be stopped up.
Also run a fuel pressure test on it.
MT
MT
Old 09-16-2006, 02:27 AM
hello, again wonder if theres a access door to fuel pump in order to change pump without dropping tank
Old 09-16-2006, 02:29 AM
yep its still that 99 buick Lesabre
Old 09-16-2006, 07:42 AM
BNaylor's Avatar
On '99 and under models you will have to drop the gas tank. It wasn't until the 2000 model year that an access cover was added which would be located behind the rear passenger seat in the trunk.
Timeslip 08/12/06
